| 6.4L Problems Forum Having Trouble? Post here |
Fog lights wont adjust?
Hey guys...when I bought my truck, one of the fog lights was pointing way up and one was not far below it. When i turn the adjustment screw...I can only get them down to the point that they are about 2" above the normal headlight line of light (pointing at a garage)...and if I try to get them lower it just clicks. Anyone had this problem? My fog lights light up street signs lol...and I assume in fog they wouldn't do any good since they basically act as brights.
Help! |
Im shooting from the hip here but I never heard my fog lights make a clicking sound when backing the screw out. Is there any issues with the fog light bracket? I removed my stock bumper for a Ranch Hand so i put my fogs on it. I had to take the fog lights out of the brackets to mount in the new RH. I will check out the brackets here after while and see if I notice anything.....
I have the same little issue now with fog lights. Youd swear i was coon hunting they shine so much higher than my headlights. LOL. Just havent got around to adjusting. Where exactly is the bracket screws to adjust them???
They're in the center on the back of the foglight. I ended up just taking the adjustment screw all the way out, chuckin the screw, and putting in two nuts and two washers on each screw and they are aligned perfectly!
