Still leaking a little oil after dealer - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-09-2012, 03:23 PM Thread Starter
acelay's Avatar
The second day of having my truck I noticed a dime sized oil spot in my driveway. Took it to the dealer, they said they cleaned it up and did the dye and blacklight test. They said they did not find where it was leaking and said it was most likely spilled oil from and oil change. We'll now 4 days later I decided to look under the truck and saw some fresh oil near the engine. I cleaned it off the engine and went on a 20 minute drive and when I got back iI looked under the truck and a little oil was under the engine again(none had leaked on the drive since taking to dealer). Should I take it back to the dealer? Let's say they do what ever they do and I get the same results, oil under the engine or maybe a little spot in the driveway. Is this something I can leave alone and just monitor engine oil levels? Thank you
acelay is offline
post #2 of 3 Old 01-11-2012, 09:21 AM
wilsonw2's Avatar
Quoted: 18 Post(s)
Monitor your oil levels and residue on top of and under the truck. Could be a lot of things. Keep a sharp eye on ur truck. My two cents.
*NEW:
2016 F250 CCSB KR FX4
NL Fab:
---Stage 1 Intake
---EGR shmock off plates
---Flo Pro Exhaust (5" to 6" tip)
---SCT with GH tunes
---Waiting for first Fuel Filter change to install:
---------CCV Mod
---------CTS2 monitor with EGT Probe
Just passed 1,111.1 miles and LOVING IT!
**SOLD:
2010 F250 CC FX4
H&S
AFE Intake
and some other goodies...
wilsonw2 is offline
post #3 of 3 Old 01-11-2012, 12:24 PM
pyro2nite's Avatar
Yes take it to the dealer. Explain you cleaned the area and the spot came back.I sure the dealer does not make much on oil leaks, so it will be easy for them to dismiss. Documentation is needed if it gets worse.
2008 FX4 SC SB 6 Speed 3:73LS, Transflow, H&S Mini Maxx, KEM Tunes, S&B Intake
pyro2nite is offline
