UPPER RADIATOR HOSE - Ford Powerstroke Diesel Forum
Old 01-03-2012, 04:56 PM
UPPER RADIATOR HOSE
I have a coolant leak that is geting worse by the day it seems. Its leaking from the hose thats to the right if your looking at the truck from under the hood.Im guessing this is the upper radiator hose i just want to verify before i order it. It runs from top right corner of the radiator to just infront of the oil filter. is this the part i need i just want to be sure?Also is there a trick to geting the clips off these hoses? Thanks in advance
BRAND NEW OEM UPPER RADIATOR HOSE ASSEMBLY FORD #AC3Z-8260-A | eBay
Old 01-03-2012, 07:23 PM
Feedback Score: 10 reviews
thats it !!!, on the back side of clip just use a screw driver or something thin just get between clip and groove and pry it , metal clip will pop right out , and to install just make sure your in the direction and in the groove and push it , clip will pop right back in place
