Front cover cavitation - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 36 Old 01-02-2012, 10:20 AM Thread Starter
Feedback Score: 6 reviews
The timing cover on our rollback corroded and puked antifreeze into the oil on a tow. Was about a gallon overfull when it got back and smoking a little. 50 some k on the truck, keeping my fingers crossed when put the new cover on and change the oil it's not f'd!
Heard some complaints of this on the forum, but this is a first for us and we own 6 of these trucks. I'm just surprised that it happened at such low mileage.
jjstile is offline
post #2 of 36 Old 01-02-2012, 03:37 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
it seems to happen on the trucks that work the hardest, mostly 450s and 550s. we've seen a couple cavitated all the way through
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #3 of 36 Old 01-02-2012, 07:26 PM
ryandamo's Avatar
does the use of coolant aditive prevent this problem, im purchasing an 08 f550 in the next few weeks and am trying to figure out all the tricks to owning these engines.
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #4 of 36 Old 01-03-2012, 12:18 AM
NVHunter83's Avatar
What metal is the cover made out of? Aluminum? Question is because my truck is slowly loosing coolant and my last Blackstone Report said I have 0.08 % Antifreeze in my oil along with high numbers of aluminum. Could this be my issue? Cavitation of the cover?
2008 Ford F-350
6.4L Power Stroke
Crew Cab Long Bed
Buck Stop Bumper w/
WARN 9500 lbs. Winch
H&S Mini Maxx w/ homemade mount
5" Flo-Pro DPB exhaust w/ muffler
Bilstein 5100s Shocks
AFe Stage II Magnum Force Intake
NVHunter83 is offline
post #5 of 36 Old 01-03-2012, 12:08 PM Thread Starter
Bingo! Ours is a 550. And it did cavitate all the way through....
jjstile is offline
post #6 of 36 Old 01-03-2012, 02:46 PM
superBADduty's Avatar
Quoted: 17 Post(s)
Garage
From what I understand the 450's and 550's get the majority of the cavitation issues because they have a higher gear ratio which makes the engine rev higher inturn making the water pump spin faster causing the cavitation.
I maybe wrong but I thought Ford (or could be an after market) came out with a new style cover to help with this issue.
2007 F250 KR CCSB 4x4 ARP's, PMM's EGR delete, PMM's coolant filter, SCT Sf3, GearHead's SRL & SRLXX, Rancho 7000's, IDP FICM tuning, blue spring, Wicked Wheel 2, No Limit Fab. CAI., 2008 rear differential cover.
2006 GMC Savanna 3500 6.6 LBZ Duramax work van
2008 F250 KR CCSB 4x4 quad buckets minimax "SOLD"
superBADduty is offline
post #7 of 36 Old 01-06-2012, 12:45 PM Thread Starter
That is correct aluminum.
jjstile is offline
post #8 of 36 Old 01-06-2012, 05:45 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
we recently put in an enhanced shortblock (reman) from ford that had a revised front cover design behind the waterpump. This is a fairly recent update from what I understand
JUGERNAUT likes this.
-Matt
2015 F-250 XLT 6.7L
post #9 of 36 Old 01-09-2012, 07:47 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
So if you order the front cover from ford it should be the revised one? Can you order the front cover by itself?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #10 of 36 Old 01-19-2012, 06:41 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Honestly I have no idea. Usually there is a TSB or something regarding the part change but in this case a shortblock showed up at our shop wearing a new designed front cover.
-Matt
2015 F-250 XLT 6.7L
