Banks CAC no fix for Smoke and Hesitation Rainy Weather - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-06-2011, 09:39 AM Thread Starter
I just had a chance to try out the new Banks CAC as i purchased it to hopefully resolve this problem. I drove steady state for 1 hour in fairly hard rains at 60F. Great conditions for testing. Then after an hour i hammered on the throttle and unfortunately still had the issue. White smoke and truck hesitates due to water in CAC. The good news is that it didn't last as long so i'm hoping the problem is at least better. Overall i'm disappointed but am glad it seems to have improved the issue. Keep in mind i've already had the replacement CAC per the TSB. I'll drive it for a few months and post back again.
2008 Dark Stone F250 CC,4x4 Lariat, Job3, 3.73 gear
Banks CAI
ATS Painted Flares
Eaton Front E-Locker
sawtooth1 is offline
post #2 of 6 Old 03-06-2011, 09:57 AM
Quoted: 5 Post(s)
Send a message via AIM to PSDfreak
Have you had the newest CAC installed per TSB 11-2-2? It just came out Feb 2011 and has a brand new part number.
I got the latest CAC installed in my truck from ford about 3 weeks ago or so and my problem is gone (FINALLY!).
'97 F-250 PSD, 4x4, ZF-5...Few Doo Dads
Tuned by TW -
-- SOLD
'09 F-250 6.4L, FX4, CCLB, 4" Pure Performance 4-Link Suspension Lift, 325/60/20 Goodyear Duratracs -- SOLD
'14 F-350 6.7L, Lariat, CCLB
RED 31
PSDfreak is offline
post #3 of 6 Old 03-06-2011, 10:16 AM Thread Starter
This must be what your referring too.
FORD:
2008-2010 F-Super Duty
This article supersedes TSB 8-25-1 to remove the production build date, update the vehiclemodel years and Part List. ISSUE:
Some 2008-2010 F-Super Duty 250-550 vehicles equipped with a 6.4L diesel engine may exhibit significant amounts of white smoke from the exhaust pipe while driving in high humidity or rainy conditions at temperatures above 4 C (40 F). This smoke only appears during a moderate to full throttle tip-in that is performed after a period of steady state driving.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
This procedure only applies if the vehicle meets the following criteria:
Concern is described as significant amounts of white smoke from the exhaust pipe.
White smoke only occurs in high humidity or rainy conditions above 4 C (40 F).
White smoke only appears during a moderate to heavy tip-in that is performed after a period of steady state driving (approximately 20 minutes)
No diagnostic trouble codes (DTCs) are present.
Concern is not a result of regeneration, a cleaning exhaust filter event.
If all of the criteria above is true, then replace the charge air cooler (CAC) assembly with a new revised part per Workshop Manual, Section 303-12.
Some white smoke may still be present under severe conditions even after the new level CAC has been installed. This is considered a design characteristic of the charge air system and no repair attempts should be made. This concern does not affect the life of the engine or exhaust components.
PART NUMBER PART NAME
7C3Z-6K775-C Charge Air Cooler Assembly
WARRANTY STATUS:
Eligible Under Provisions Of NewVehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
110202A 2008-2010 F-Super Duty 6.4L: Replace The Charge Air Cooler, Includes Time To Check For DTCs (Do Not Use With 6775A, 12650D) 0.7 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
6K775 42
I've had the original, then the TSB unit but not a revised one. So are you saying you had the 1st revised CAC per the original TSB and now your on your second one for the latest TSB in February?
Banks CAI
ATS Painted Flares
post #4 of 6 Old 09-19-2011, 11:04 AM
2008 - New CAC no fix
I don't have an aftermarket CAC but I got the new CAC from Ford under warranty a couple months ago. The new CAC did not fix my issue. In fact, the symptoms seem to be getting worse.
I've had a Chevy truck, Dodge SUV (gas), two GMC SUVs (gas), and now a Ford diesel 6.4L. I never have had a really solid vehicle yet. But this issue is downright dangerous. I envelope other cars in white smoke and I can't accelerate safely due to the serious engine stumble around 2500RPM.
SpoolUp is offline
post #5 of 6 Old 09-23-2011, 12:19 PM
Send a message via Yahoo to skipnay
Had this numerous times. I have installed the H&S Tuner and hasn't done it since. Never got a call about a fix for that either. Would be nice to have it fixed if I ever have to go back to the DPF/Cat...
2010 My Wife has 2 Full time JOBS NOW
2008 F250 H&S MiniMaxx, S&B CAI, and cat/pdf delete
2008 Brute Force 800 All hooked up 67hp to the wheels
2007 Got Married
2004 KFX 700 Stock Bore Kit XX cams
1990 Mustang Notch getting ready to hook it up
1988 Mustang GT 449hp to the wheels 6sp Getting a cage installed
skipnay is offline
post #6 of 6 Old 09-23-2011, 12:35 PM
Got the new CAC. No fix.
Dealer installed a new EGR valve and EGR cooler Tuesday. Not sure if that fixed it. I need the right conditions. I'll know when I pull my boat or in humid weather.
SpoolUp is offline
