P2263 code - Ford Powerstroke Diesel Forum
post #1 of 14 Old 02-17-2011, 08:49 AM Thread Starter
P2263 code
I no its been asked a million times but my truck keeps throwing the P2263 code, now i bought the truck from a place 2hours from me that wasnt a ford dealership, i still have almost 3 years and 50k miles left on the ford warrenty, and 2 years 24k miles from the place i bought the truck. what should I do? if i take the DPF and tuner out and set it back to stock will the check engine light go out so when i get to where ever they say they cant help me because the lights out. and if they run the computer will they find the tuner? and if they do find it can i say i bought it used last year so they might of had one and takin it off before they traded in. I need to get this fixed ASAP, i just bought a house and make settlement in 3 weeks so im gonna need it for moving and all. thanks guys.
Oh yea its a 2008 job 1 with spartan 275, with 47k miles
futbal2332 is offline
post #2 of 14 Old 02-19-2011, 11:12 AM
I just had these same codes, and I've got the same tuner with the same tune loaded. Mine ONLY did it when it was freezing outside. Once it warmed up to about 25 degrees, it hasn't come back. But on the days it was near 0 outside, it kept popping up.
I'd ride it out til the warmer weather.
CarTeksValpo is offline
post #3 of 14 Old 02-21-2011, 12:06 PM
Im guessing your ebp sensor on the drivers side exhaust manifold is on the fritz. Drive it for a bit longer and see if any other codes pop up.
Skolness is offline
post #4 of 14 Old 10-09-2011, 11:29 AM
sanman28's Avatar
Mine threw this code today while I was pulling about 9k lbs uphill under pretty high boost and throttle, hot damn set at mild. I cleared it and kept on pulling to my destination and it never came back on. Anything to worry about?
2010 CCSB FX4. Mini Maxx/Gearhead, Deletes, H11 Studs, Up-pipes, 4" DP, 5" Back, CAC, Elbow, CCV, CAI, Custom Heads, Elite Transmission
FBHO
sanman28 is offline
post #5 of 14 Old 10-09-2011, 11:46 AM Thread Starter
I wouldnt worry about it, my truck throws it atleast once a day, sometimes 4,5 and 6 times. im just use to it now. never had any other problems. i wish I knew why it always comes on though
post #6 of 14 Old 10-09-2011, 12:20 PM
sanman28's Avatar
Faulty sensor.......
FBHO
sanman28 is offline
post #7 of 14 Old 10-18-2011, 06:40 AM
Pmac21's Avatar
Mine will throw this code too. Mine always does it at idle though. Two weeks ago I made a trip from memphis, tn to little sahara sand dunes in west oklahoma and a few times when I stopped for fuel it would pop up. What would cause this? and btw I am running the spartan 275 and at the time I was pulling a 16' trailer with 3 sport atv's.
2008 Lariat Crew Cab F-250
Spartan 310, AFE intake, 4" down pipe,Straight pipe, ARP's, EGR delete, Flo Pro intake elbow, Chromolly push rods, CAC, BatMowheel! High idle mod, 5000K HID Hi/Low and Fogs, Bilstein 5100's
Pmac21 is offline
post #8 of 14 Old 09-05-2013, 04:02 PM
mmandley's Avatar
Anything new with this code?
I was towing this weekend for Labor day up a 6% grade, apx 7500lbs, i got stuck behind a slow car doing 50 and my exhaust temps set at 1100 for a good while.
Once they got out of my way all i could do up the hill was 50mph, i only had 20psi of boost, 440 torque and the truck wouldnt downshift to 3rd to allow me to get back in my power band. EGTs would only allow me to hit 880.
I check my codes while driving and this was the only code. I cleared it and it returned. 2xs and then finally i just drove it like i was in a gas truck.
Got to my destination, then the next morning truck ran great, all the way home on the same grades truck was a beast, pulling up the hills doing 75 no problem, boosting to 38 psi, egt was 950 and torque was 800 again. Ran perfect.
I'm still concerned because next week we are towing the boat to AZ from OR for a week at Powel and i dont want to get stuck with this issue.
I'm looking for any ideas for things to inspect or anything.
08 F350 6.4 Lariat CC LB tows a 13 Moomba Mojo 2.5
2inch Level kit
Mini Max tuner
S&B CAi
Diamond Eye 5inch exhaust straight pipe
HID headlights, and Fog lights
EGR delete <planned next>
Ladder bars <in the future>
mmandley is offline
post #9 of 14 Old 09-05-2013, 06:01 PM
Pmac21's Avatar
Mine still throws this code but, only on spartan 275 tune and at idle. Usually happens when I'm getting fuel. I reset the light and have never noticed a change in performance.
Pmac21 is offline
post #10 of 14 Old 04-01-2016, 05:05 AM
Torque's Avatar
Digging up from the dead. Got this code on yesterday and cleared it with my Spartan. Anyone ever figure out the reason for the code.
09 F250 CCSB FX4
Spartan Tuned, 4" Downpipe/Exhaust, No Limit Intake/Cold/Hot Intercooler Pipes, BD Manifolds and Up-pipes, MPD CCV, ARP Head Studs, Spearco Intercooler, Sinister Coolant Filter, CAT Coolant, PTP Modified Direct Clutch Solenoid, Pro-Comp Pro Runner Shocks/Dual Steering Stabilizer, Daystar Cab Mounts
Torque is offline
