Odd idle? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-29-2011, 03:34 AM Thread Starter
Chasin' Tail's Avatar
Odd idle?
Towed about 8,000 lbs of Hardie board Friday morning as I was unhooking the trailer I let the truck idle. Every so often exhaust note would change and sounded like turbo was spooling slightly. Is this just turbo cooldown? MY egt's never got any were near overly hot though.
10' 250 King Ranch
Spartan Tuned
Afe Intake
Dpf/Doc Delete
Chasin' Tail is offline
post #2 of 9 Old 01-31-2011, 04:56 AM Thread Starter
Anyone?
10' 250 King Ranch
Spartan Tuned
Afe Intake
Dpf/Doc Delete
post #3 of 9 Old 01-31-2011, 05:59 AM
mo powerstroker's Avatar
mine does that I don't think there is a problem. It seems like with the 6.4 having a dpf delete all i hear is turbo all the time
mo powerstroker is offline
post #4 of 9 Old 01-31-2011, 06:14 AM
GreenF350's Avatar
I don't know the details, but I know at least some of the 6.0's did what you are describing and it is supposed to be the EGR cycling. My buddies truck will do it all the time. Not sure if it might be the same thing on the 6.4 or not.
-Aaron
2000 Ext. Cab F350 SRW, 6" Skyjacker lift on front/8" BDS Springs on rear w/NO blocks, 37x13.50 Nitto Mud Grappler's, Aftermarket Front Bumper
-Always More Stuff Coming!
GreenF350 is offline
post #5 of 9 Old 01-31-2011, 05:31 PM
RobertS450's Avatar
Quoted: 14 Post(s)
I bet its the VGT cycling on the turbo. The ISX cummins in are work trucks do that at idle to keep the mechanism from sticking
Robert
2010 F450 CC LB 4x4 Black.
RobertS450 is offline
post #6 of 9 Old 02-10-2011, 01:58 PM
Your signature says your Spartan tuned and DPF deleted. Spartan tunes cycle the EGR valve at idle to keep them from sticking shut. Nothing to worry about ,mine does it too.
Antonm is offline
post #7 of 9 Old 02-22-2011, 09:18 PM
CEEEJ's Avatar
i hear mine cycling all the time. h&s tuned.
2008
F250 FX4 CCSB
H&S XRT Pro / Stealth Delete
No Limit Cold Side Kit w/ egr gone
Icon 2.5 Level w/ adj track bar
OEM F350 blocks in rear
CEEEJ is offline
post #8 of 9 Old 02-23-2011, 05:26 AM
Remi19's Avatar
Same here, turbo and loud rumble
Remi19 is offline
post #9 of 9 Old 04-04-2011, 12:45 AM
crossinwiresisbad's Avatar
Yep, Black maxx tuned and mine does the same thing. Cycles the vanes think. Anyone get a kind of grumble noise when you let off the gas. Happens for a few seconds and then engine idles normal???
crossinwiresisbad is offline
