| 6.4L Problems Forum Having Trouble? Post here |
Bad EP sensor?
Been reading the threads after noticing P2263 and P2563 codes coming up on DD. Went down and performed key on/engine off test and came up with the following data: (Exhaust back pressure-absolute = 52.1, Barometric pressure = 14.7 & MAP was at 15). What does this tell me? Is it telling me the EP sensor is bad because that should also read close to atmospheric pressure? Please chime in Ford techs! Also about what it should cost to have this replaced.
I just replaced mine. I was getting the same codes as you. The sensor is about $80.
Does anybody know the part number of the EXhaust Back Pressure Sensor so I don't screw up when I order one. I am also getting the P2263 code when the truck is under a load and pulling long/steep hills.
Thanks in Advance, StickThrower |
Thanks 04hdfatboy,
Man that was fast. I hope this fixes my problem! Thanks again, StickThrower |
No problem bud. I threw that same code. I replaced the ebp sensor and it never came back. Good luck!
Just an update I replaced the EBP sensor. That did not fix my problem, although I believe it did wake up my turbos. So I ended up taking my truck and trailer into the ford dealership and they updated my ECM/ECU That fixed my 6 month long turbo issue.
Thanks for everybody's help, Stickthrower |
