Radiator broke dealer wont cover! - Ford Powerstroke Diesel Forum
Old 01-03-2011, 05:36 PM
2008 F250 Job 2 bonestock
Bring truck to dealership for coolant leak. Truck has 35500
on the ticker. I am second owner. First owner purchased in Sept 2007. So
dealership says over the phone dont worry we will take care of you. Well
they are not now. Since I am second owner cant cover under warranty. But
if they pull the stats out and see they caused it they can do it. $1500 just for
radiator repair. Extra $500 to check stats. So I call the dealer where it came
from for repairs. The last time in shop was for low power. They changed the
top temp sensor and back to normal. Could the temp sensor have caused
the radiator problem. Now the big question what should I do.
1. Let dealer do stats and hope they caused the problem.
2. Call ford public relations and complainto see what they do.
3. Just fix radiator and hope nothing else goes wrong
Old 01-15-2011, 09:24 PM
That sucks They had a boat load of 08 that had radiator problems this is nothing new, i would call Ford check another dealer
2 stroker
Old 01-16-2011, 04:58 AM
would find new dealer also....
Old 01-16-2011, 05:49 AM
you are covered.
Old 01-16-2011, 06:35 AM
Whether you are the first of 31st owner shouldn't be an issue. If it's within the warranty period, you are covered. Plus, many of the 08's had radiator issues and there is a TSB (I believe) that covers this. As stated above, I'd find a new dealer or call Ford owner support.
Old 01-18-2011, 12:23 PM
Well i have to say ford did right by me on this issue, i just had my truck in for service and they found an antifrezze leak so after testing they changed the top rad hose thermastat & rad!! all covered!! I have to give ford props for this and not cheaping out.
Old 02-01-2011, 06:20 PM
ive heard of people getting them replaced at like 85k. your still under the bumper to bumper and should be covered for sure. my dealer wouldnt cover my chirping idler but a dealer 90 miles away did. some dealers just suck
Old 02-02-2011, 06:14 PM
Powerstroke Techie
Feedback Score: 3 reviews
radatiors are covered under 3yr 36k. thermostats are not the problem with this particular concern and you are not going to get a rad under powertrain any longer
also i have not yet seen customer relations give any $ for a rad repair. yes it does suck
Old 02-03-2011, 06:03 AM
well if the first owner purchased it in 9-07 then the 3yr 36k warranty ended in 9-10 and your going to stuck with the bill unless they can prove the t-stat is the issue, then it will be covered by the 5yr 100k motor warranty.
