water separator - Ford Powerstroke Diesel Forum
Old 12-24-2010, 11:09 AM
water separator
My water separator light keeps coming on. I have tried to drain it but it only dripps alitte but it looks like only fuel is comin out. Any ideas?
Old 12-24-2010, 11:30 AM
PROUD AMERICAN!!!
Feedback Score: 5 reviews
Maybe try cleaning the WIF sensor.
Old 12-24-2010, 12:56 PM
Thanks do you know were that sensor is located?
Old 12-24-2010, 03:22 PM
Retired Army
Your drain valve may be clogged. You might need to take it apart and clean it out but you will need a new gasket for it. Also if it is coming on every 2 or 3 hudred miles you may have a bad sensor. In my 2010 the sensor went bad and it was replaced under warranty. It took a bit but they finally did that and it quit coming on. I drain it once a month and even took two of the bottles that I had drained fuel into to the dealership so they could see what was in it..... good luck
Old 12-24-2010, 05:05 PM
When you drain your does it drip or is there a stream that come? The light comes on after 10 to 15 miles.
Old 12-24-2010, 05:13 PM
Retired Army
Mine drains for a few minutes. You might try Seafoam, it will help disappate water but sounds ot me like you got a clogged drain. Seems like the ULSD reacts with water and leaves a residual buildup. I read that on here but can't remember in what section. I would that that the sensor is bad if it is coming on that often
Old 12-24-2010, 05:56 PM
Thanks ill try seafoam an cleaning it out. Id say the sensors are not cheap.
Old 12-24-2010, 07:37 PM
shhhhh, can you hear it?
i would have it cleaned.take it apart.there are a few threads on it on here.do a search.
Old 01-03-2011, 12:40 AM
Try opening the drain with it running then close it and shut motor off and open it again. It worked on mine.
Old 01-04-2011, 06:32 AM
i am having the exact same problem. Mine drain water seperator is coming on every little while. I think its a bad sensor. Hopefully i can afford the fass fuel system soon.
