| 6.4L Problems Forum Having Trouble? Post here |
Help!! truck is going crazy!
Okay so my friend has a stock 350 6.4. Driving down the road the other day and all of a sudden the dash says "Stop Carefully Now" or "Stop Slowly Now". As soon as he stops the truck shuts off. He waits a sec and tries to restart and it wont even crank. Two hours later the tow truck shows up to get it and it starts right up no problems.
HELP! |
Thats happened to a few guys here. If i remember correctly it was an issue with their DPF clogging or something like that. The DPF is part of the Emissions warrenty, which I believe its covered for 7 years.??
Anywho.... good luck hope this helps. Dom |
One tech saisd it could be a bad key chip, does that sound possible? It runs fine now but just wouldn't crank for an hour or so.
I don't know about a bad key chip but if the DPF gets to hot that's what it will do, or if you have a faulty exhaust sensor the computer thinks its to hot and does the one hour shut down. Was it in cleaning mode when it happened?
