truck won't strat - Ford Powerstroke Diesel Forum
Old 11-17-2010, 03:32 AM
truck won't start
08 6.4 47k miles totally stock minus leveling kit.
i went out this am and the after serious rain last night, got in the truck turned the key on and waited to start it, when the light went off i hit the key and nothing- not 1 sound or noise of the truck trying to start.
i cycled the message center and it said all was ok- the radio and lights all work- both batteries show green-
could it be the starter already or something like a fuse or such?
bad day for this- trailer hooked to truck loaded with stuff i need to have on work site this am and i am an hour away at home with my boss freaking out!
Old 11-17-2010, 04:22 AM
Possible EGT sensor went bad. There is a connector near the passenger side battery you can jump to get it started, if the EGT sensor is the problem.
Old 11-17-2010, 04:23 AM
i know this sounds silly- but are you able to walk me thru this?
Old 11-17-2010, 04:51 AM
i see a connector with some sort sensor in it at the end of a wire run, i took it off and tried but nothing- i dont know how to jump this. i also see some sort of in line connector on the positive cable that heads down under motor to something?
Old 11-17-2010, 05:50 AM
i may have overlooked this earlier. the mesage center says check charging center
Old 11-17-2010, 06:12 AM
If you have a Job 1 it could be a problem with the TCM... This happened to me Monday, batteries fine but it wouldnt turn over at all. Good luck though.
Old 11-17-2010, 06:14 AM
yes job 1 truck. how do i trouble shoot that? dealer or..... thanks by the way!
Old 11-17-2010, 06:16 AM
how did you handle it and make out?
cc lb 4x f350 lariat
early job 1 07 build
Old 11-17-2010, 06:29 AM
Mines early job 1 07 too anda bout 42000 miles on it. Well I called spartan and told them what had happened and thats what they said.. I had to get it towed to a local auto shop and theyre fixing it. Apparently the Job 1 TCMs are pretty flaky and can just give out. If you still have a warranty I would just get ford to deal with it..
Hopefully today ill have my truck back and running
Old 11-17-2010, 06:32 AM
thanks! good luck to you.
