| 6.4L Problems Forum Having Trouble? Post here |
drain seperator for 2008 ford f250
Do you drain until it stops shooting out.
Until pure, clean diesel comes out.
When do you drain it?? When a light comes on or is a monthly thing??
Carl |
I drain mine about every 1,000 miles.
-Mike |
I drain mine on the 1st of every month.
you could always keep a bottle with you and do one before every fill up.or as often as you like.i would do it prior to fill up but i dont think it would much matter as it is not attached to the tank
Could be a stupid question but here it goes. What does everyone do with the fuel that drains out.
use it as lighter fluid.if you use a good clean bottle and there is no water in it (looks like air bubbles on the bottom) you could pure it back in,kill ants with it,mix with styrofoam to make napalm,the list is as long as your imagination.
Real men drink it.
I use it at the campground or in my fire pit to get things going. If you are at a campground and find yourself with wet wood and no liquid "help", grab a bottle, get under there and get it right from the tap. This little convenience has saved my rear a few times on cold damp nights.
