Radiator Repaired. Now have Supercharger whining sound. - Ford Powerstroke Diesel Forum
Old 10-21-2010, 07:43 PM
I had my radiator repaired at a local radiator shop. The shop has had a few 6.4's come in for the same problem because ford doesnt fix under warranty. well now truck has supercharged whining sound. brought back to radiator shop and they found a hose r something by the turbo that was loose they said, also stated that my cooler had oil in it and they cleaned it really well along with repairing the radiator. The turbo was change under warranty from the previous owner i bought the truck from. Hopefully it didnt mess my turbos up with the dirty cooler. now the supercharged whining sound is gone. When i floor the truck it sounds like im pushing a whole lot of air through the exhaust , like a loud swishing sound almost how my first 08 sounded with the dpf and cat delete pipe. Dont think it should be sounding like this. any help would be appreciated thanks.
Old 10-24-2010, 07:35 AM
Ok the radiator shop said something by the turbo was loose and the whining sound went away. But now it's back again but only around 3000 rpms.
Old 10-30-2010, 11:49 AM
Check all of you boots. Sounds like they may have left something loose. How much did they charge to repair your raidiator? Did they say what exactly was leaking?
Old 10-30-2010, 12:05 PM
It had 2 leaks. They also cleaned the cooler . Charged 650. The noise was loud . They said a line by the turbo was loose they tightened it and it makes a noise at 3000 rpm.
Old 10-30-2010, 05:08 PM
I would think if you were not out of warranty it should be fixed by ford. I have had 4 radiators all for leaks and all replaced by ford.
Old 10-30-2010, 05:42 PM
Served Our Country!
Feedback Score: 3 reviews
Send a message via AIM to HighOn20s Send a message via Yahoo to HighOn20s
Its an 2008 and the Turbo has already been replaced and the Radiator had a leak... how many miles are on the truck?
Still under warranty and they said they cannot fix the problem because it was replaced at an earlier mileage. Which I think is bull:::: because they replaced it and it leaked again. So I told them I'm not paying for a 1500 dollar radiator tomjust start leaking again. So I had it fixed by my local radiator shop. I think this warrany stuff is way over rated.
Old 10-30-2010, 05:44 PM
Truck has 84k miles
Old 10-30-2010, 05:45 PM
Served Our Country!
Did Ford replace it the first time?
Old 10-31-2010, 05:30 AM
i was told if the radiator leak is found to be caused by a stuck thermostat it is covered under the motor warranty.
