Brake pedal Click??? - Ford Powerstroke Diesel Forum
Old 10-08-2010, 08:42 PM
2010 F350
Pulled into my driveway and put my foot on the brake to put the truck in park. When I released the brake pedal ...there is now a loud clicking noise when I push on or release the brake pedal. The really odd thing about the noise is that, it is a loud clicking noise with the truck running and a faint clicking with the truck off. What the HECK is this all about?
Old 10-09-2010, 04:05 PM
Got my head down under the dash,the noise is actually coming from the steering column. After a little more experimenting I found it would only make the noise with the truck running in park...Figured out it is the switch that requires you to have your foot on the brake pedal before you can take it out of park.
Old 11-06-2010, 06:42 AM
yeah the shift interlock solenoid makes a loud click when its energized and de-energized. the click is the plunger touching the contacts inside the solenoid. usually when they go bad, it will gradually get louder, most of the time its not all of a sudden so i'd say its ok.
Old 11-11-2010, 06:50 AM
Thanks for the info Firefighter, it is exactly as you said...the solenoid clicking.
