Whistling noise? - Ford Powerstroke Diesel Forum
Old 09-05-2010, 06:18 PM
Whistling noise?
I'm 3 hours from home @ a cattle show,I searched the forum and I believe it could be a crack somewhere around the turbos, y pipe maybe? It makes a whistling sound at low rpm and then a lot louder as rpm goes up, it's stock and seems to be boost the same, can I drive it home w/10000lbs on? thanks.
Old 09-06-2010, 05:37 AM
I would not hesitate to drive it home. Mine has some sort of leak around the up pipes and I drove it from Dallas to Orlando and back with the 5th wheel without issue. Mine goes in Wednesday for the repair.
