Limp Mode... Forced Regen??? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-21-2010, 03:16 PM Thread Starter
CCSracer13's Avatar
I need some insight guys.
I was pulling into the parking lot of the local Target in my truck today and all of a sudden, the gas peddle doesn't work. I park the truck and it goes into high idle. At this point I am wondering if it is some type of forced regen process, so I let the truck run for a half hour. It never comes out of high idle and giving it gas does nothing to affect the RPM's. However, if I hit the brake, it will idle back down. So, I am forced to drive it back home and just let the high idle push me home at about 20 mph since the truck is ignoring the gas peddle. I did see the "cleaning particulate filter" flash once, but it had been at high idle for an hour and would not come out of limp mode.
So, I shut it down and pulled four codes:
P0652 Sensor Reference Voltage B Circuit Low
P2452 Diesel Particulate Filter Pressure Sensor A Circuit
P2454 Diesel Particulate Filter Pressure Sensor A Circuit Low
P2002 Diesel Particulate Filter Efficiency Below Threshold (Bank 1)
I have an S&B CAI, so I have received P2002 before. But it is the first time for the other codes. The truck is an '08 and bone stock other than the S&B.
Thoughts??? Is anybody familiar with these codes or had this happen before?
CCSracer13 is offline
post #2 of 4 Old 08-22-2010, 07:52 AM
Powerstroke Techie
I have seen this before.
The concern was there when the truck arrived at my dealer. By the time I had gone to get the scan tool, and came back out to the truck, the concern was gone. Could not duplicate, ever. It had just had a PCM, pedal, and DPF pressure sensor changed at another dealer.
You have a short somewhere, dropping VREF voltage. It's going to be not very much fun to find, I'm thinking.
You could also have a faulty sensor on the VREF output from the PCM...
Either way, it's not fun to diagnose, even less fun to fix. I had almost 8 hours tied up in searching for this thing, engineering was no help.
Still never found it, and the concern has never come back, and it's been over a year.
Keep me posted with what you find.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #3 of 4 Old 08-22-2010, 11:50 AM Thread Starter
CCSracer13's Avatar
I crawled under the truck to take a look at everything this morning. The EGR Valve Pressure Sensor has been melted into a giant, unusable piece of crap.
I have been thinking about a DPF delete and tuner. As a matter of fact, I have been looking at the H&S Mini Maxx which just happens to not require any sensors in the exhaust.
Does anybody know if this would let me avoid having to purchase another EGR sensor? I looked at the H&S site and it says:
Step 1:
Unplug all exhaust sensors. Do Not remove sensors from exhaust pipe, only unplug electrical connector.
Step 2:
Disconnect rubber pressure tubes where they attach to the pressure sensor.
This makes me think that I would still need the pressor sensor, just not the other sensors. I plan on calling H&S tomorrow, but thought one of you guys might know.
Name:	EGR Valve Sensor.jpg
post #4 of 4 Old 08-22-2010, 12:56 PM
Powerstroke Techie
I would start there for your loss of VREF.
Does the truck still have warranty?
