Coolant is Dissapearing!!!!! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-14-2010, 07:48 AM Thread Starter
Dont Mess With Texas!
ThirdCoastStroker's Avatar
Quoted: 14 Post(s)
I was extremely low on radiator coolant so took it in and had a flush done and i have been watching it for 2 days and i have lost about an inch at the resevoir but there is not a drop of fluid under my truck everytime i look and nothing underneath the motor or on the frame or anything?!?!?! where could it be going and why?
any knowledge on this would be greatly appreciated thanks
Casey
New Truck
15' F-350 King Ranch 4x4 CCLB
Platinum White / Caribou Metallic
Stock for now!
Old Truck
08' F-350 King Ranch 4x4 CCSB
H&S Mini Maxx 300 HD
5" Straight Pipe to 7" rolled tip
AFE S2 PDS
ARP Head Studs
FloPro EGR Delete with Intake Elbow
FloPro CAC pipe
Rebuilt beefed up OEM Up pipes
Deisel Site Coolant Filter
Firestone RideRite Airbags
Leveled
35X12.50R20 ProComp Xtreme A/T
Ranch Hand Front and Rear Replacement Bumpers
ThirdCoastStroker is offline
post #2 of 6 Old 08-14-2010, 07:56 AM
Quoted: 5 Post(s)
head gaskets.
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #3 of 6 Old 08-14-2010, 08:01 AM Thread Starter
Quoted: 14 Post(s)
would that be covered under warranty because i have 73k miles and i know my radiator alone is not under warranty any more but my motor is up to 100k i beleive???
Casey
New Truck
Stock for now!
Old Truck
AFE S2 PDS
ARP Head Studs
FloPro CAC pipe
Leveled
post #4 of 6 Old 08-14-2010, 08:04 AM
Garage
its probly going it the the eng. oil or its buring in the cylinders go the a rad. shop and they should hav e tool to test foe exhaust gas ext gas in the rad and that will tell you whats going on
96 F-250 EC LB 4X4
The Ole-Girl
5in dumped
4in susp on 35's
adrenaline Hpop
and a bunch of little stuff
chippy is offline
post #5 of 6 Old 08-14-2010, 08:04 AM
Greenshield's Avatar
EGR cooler possibly as well. Gaskets and EGR are under the warranty.
2008 F250 CC Lariat Shorty 3.73 Limited Slip, manual locking 4wd, Rhino Lining, Custom seat back TV/DVD systems.
Reese 1200 lbs. Straight Line Dual Cam WD
2010 Rockwood 8317RKSS Travel Trailer @ 33' and 8200 Lbs. GVWR
Greenshield is offline
post #6 of 6 Old 08-16-2010, 04:10 AM
If you have warranty left you should be fine. If the radiator is leaking because of higher pressure made by bad thermostats,etc they'll replace it,etc.
2011 6.7 3.55 ELA Crew Cab 18in wheels,SRW Short Box Lariet and Lance 820 8ft. Fisher HD Plow Cobra 29 NWBT Garmin 1490T
2 place Aluminum Sno Pro V nose enclosed trailer with Tie Down Hydrolic Disc Brakes
truckinguy is offline
