| 6.4L Problems Forum Having Trouble? Post here |
DTC codes need help!No power
hey guys, first of all the truck is a 2010 6.4 with 50,000km.DPF deleate with 4inch turbo back,spartan 250,s&b intake.
the problem is my egts dont read anymore and i am getting the following codes p04d p1000 p1635 tire axle? u0100 does any1 konow what these mean? I know p04d is the egrta sencor.....the truck runs fine , but i put it on stock dpf deleate and it had a hard time getting to highway speeds.I now have it on 40hp dpf deleate , but have not had a chance to drive it. any help is appericated.... |
The EGRTA sensor is bad. It can be replaced cab-on, but is a little difficult to get to, it is on the passenger side up-pipe.
^^^ What he said.
Pull the RH inner splash shield out, and you can see it pretty easily. Heat the bung up in the pipe, hit it with some GOOD penetrating oil, and wind it out. If it fights you, just keep heating it gently until it moves freely. You ABSOLUTELY DO NOT want to haul the threads out of that bung -- up-pipe replacement is likely necessary afterwards (you CAN re-tap the bung, but I haven't had a great deal of luck with that process, usually it completely destroys the threads on the way out...I live in the salt belt) and that is not very much fun. The P1635 is likely because of bigger tires. Can also be from the wrong axle ratio programmed into the PCM, or a corrupted VID block in the PCM. But I'd put my money on the bigger tires. Hopefully both of our replies have been of some use to you. If you watch your EGRTA PID on your Spartan, I would bet that it's jumping all over the place, OR staying at 140 degrees, OR at -40 degrees. |
