No Brakes, Fluid is gone - Ford Powerstroke Diesel Forum
Old 06-17-2010, 11:32 AM
08' 450, put fluid back in and still nothing.
WTF? why would the fluid be gone all of a sudden?
Old 06-17-2010, 11:36 AM
Chapter Director
Send a message via AIM to Fantom
Sounds like you've got a leak in a line or the master cylinder.
Old 06-17-2010, 11:37 AM
Tell me that is out-of-warranty(3/36,000)?
Old 06-17-2010, 11:40 AM
Chapter Director
If it's a bad master cylinder should be covered under your 3/36 (unless that's gone) but if it's a brake line that rubbed, most likely won't be covered. I had an 04 XL that a wheel rubbed a hole in the brake line and it cost me $334 for a new one from ford
Old 06-17-2010, 12:02 PM
Seeing the leak now on the drivers side rear axle.
This truck!
-dead batteries
-tranny fluid completely gone one day
-dpf out (blue/black smoke all over the f'n road)
-radiator leaking, both upper and lower
-squeal coming when turning on the AC
-cd player won't spit out the cd
-egr sensor out
-no fluid in the rear diff.
Old 06-17-2010, 12:05 PM
Chapter Director
You sure it's not a dodge? Man, that sucks. Sometimes it seems like one thing after another. At least it's just the brake line and not the master cylinder
Old 06-17-2010, 12:32 PM
I've must of increased Coors Light's stock a couple of points this past year with all of the stuff going out. You just don't know if it will be covered and then if not, how much is it going to cost?
Old 06-18-2010, 12:42 PM
Caliper went. $580.00. woah. Talked to the dealer though and feel that it was from another dealer that just installed the rotors and pads. I guess they have to "prove" that it was from the other dealer though. Not sure how this is going to go.......
Old 06-18-2010, 02:04 PM
Chapter Director
Hopefully they'll just do the repair and charge the other dealer for it.
Old 06-18-2010, 02:13 PM
Yeah but if they don't I'm going to be pissed. Caliper shouldn't go out of the truck like that and it shouldn't be my fault, WTF?! That is a serious issue to have your brakes all of a sudden go out. It's not like a wear and tear issue either.
