P0401 - Ford Powerstroke Diesel Forum
Old 05-15-2010, 07:09 AM
P0401
(P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient Detected)
Anyone know what causes this? This is why I got the Spartan so I could delete this code but would one day like to find a real fix. I do have a after market ext.
Old 05-28-2010, 12:37 PM
Found it, due to an coolant leak that I still cant find..
Old 06-01-2010, 08:26 PM
I just got the same code and I check for and I cant anything
Old 06-03-2010, 07:27 AM
I put my truck back to stock and the codes went away and the coolant is now fine. Are you running a Spartan?
Old 06-03-2010, 05:35 PM
Yeah I do. I barley 8000 miles with spartan.
Old 06-03-2010, 06:35 PM
I got about 6,000 miles with my spartan.
Old 06-06-2010, 07:25 AM
Ok so did you put everything back to stock like dpf delete and intake? or did you just load the stock file thru Spartan??
Old 06-06-2010, 07:36 AM
I put every thing back to stock for now. I updated my tuner and Mick sent me the new strategy tunes and I am running a stock plus 125hp tune with no problems. The only problem I ran accross was that the tuner no longer liked my stock tune any more. Mick sent me a new stock file and all seams well for now. THANKS MICK.... I will run it with the stock plus 125hp for a few more weeks to see if any codes pop up. If not I will be removing the dpf again.
Old 06-08-2010, 07:28 PM
Oh ok Ill try that THANKS
