| 6.4L Problems Forum Having Trouble? Post here |
check engine light
I just installed the S&B cold air intake on my 6.4 and the check engine light came on, i have no programmer on it.What is the best thing to do? Should i be worried?
Don't worry, just check to make sure you plugged everything back in. If you did plug everything back in, see if someone near you can check the code. You are one of the few that get the S&B and throw a code, it's just more air than the engine is used to, unless you did leave something unplugged.
yea i checked everything and its all plugged in, where can i go to get it looked at besides a dealer?
Check around at local shops and ask if they have a scanner that will work on your truck.
