Tire monitor error? - Ford Powerstroke Diesel Forum
Old 03-28-2010, 04:34 PM
Tire monitor error?
Ok I put 38's on... and put the monitors on the new rims too... and im gettin a "tire pressure monitor fault"... not low tire pressure... how do I fix it?
Old 03-29-2010, 08:54 AM
also if I turn the truck off and let it cool down and sit for an hour or 2 it will go off and about 30 mins into driving it will come back on
Old 03-29-2010, 10:13 AM
Powerstroke Techie
Retrain the sensors to the truck, make sure the pressures are right, and make sure the sensors are able to transmit trough the tires.
Make sure the sensors aren't damaged, also. They are fairly easy to damage during installation/removal of tires.
Old 04-02-2010, 11:08 AM
I'm having this same problem. Only difference is mine does it the instant you turn the key on. I've taken it into the dealer and they are no help at all. Is there any way to check the sensors without dismounting the tires? Sometimes it says "Tire pressure sensor fault" on the screen and other times it says "Tire pressure monitor fault" and it comes on immediately every time I turn the truck on.
Thanks
Old 04-07-2010, 03:19 AM
i have the same problem with new 37" i just put on... ran on them for about 100 miles and then the tire "sensor monitor fault" came up is there a way to reset these? i have a bmw and there was a way to reset the sensors when you filled the tires up to the right pressure... any help from anyone?
Old 04-18-2010, 04:57 PM
What is the pressure in tires you all are running? I know some of the bigger tires are run at lower pressures than the stock ones that the TPMS was designed to work with.
Old 04-18-2010, 07:39 PM
What we are all getting here is a monitor fault, not a low pressure reading. Looks like it's time to dismount the tires and look for faulty sensors
Old 04-19-2010, 12:53 AM
Warheads on Foreheads
can you guys just run the tires with the faults and forget about it? do these sensors effect ABS?
Old 04-19-2010, 07:16 AM
I am now getting the same fault with my new 38s and bmf wheels...
