ABS light - Ford Powerstroke Diesel Forum
Old 02-28-2010, 10:36 AM
ABS light
I don't know if anyone else has had this happen. My ABS light has come on intermittently. It has happened 3x. My radio will go off and the ABS light will come on, it only comes on for less than 15 seconds. Haven't had any other issues. Anyone heard of a problem like this? Thanks
Old 02-28-2010, 12:15 PM
have your batterys checked out.I see you have a 2010 but my 08 had the same symptons and it ended up being the batterys.I wouldn't think your batterys are not bad but you never know it might also be a loose connection.
Old 02-28-2010, 12:38 PM
Thanks, I will check them. I also have the dual alternartors, so it should not be a power thing?
Old 02-28-2010, 12:45 PM
Feedback Score: 5 reviews
Mine was coming on every now and then like that. I also noticed if I was on the highway with the cruise control on, if the ABS light came on it kicked the cruise control off and I had to reset it. The ABS sensor and vehicle speed sensor are the same one on the rear end. Its mounted right above the pinion. I found a guy parting a truck out and bought that one as well as the two front ABS sensors. I changed the rear one out and its been fine every since.
