P2289 Injector Control Pressure Too High - Engine Off - Ford Powerstroke Diesel Forum
Old 02-18-2010, 03:19 PM
a truck
Exclamation Help!-P2289 Injector Control Pressure Too High - Engine Off
Ok so driving home today I noticed my truck was running weird, it wouldnt go over 12,000 psi of fuel rail pressure and was making 45+ psi of boost on my 210 tune when before it made 32 tops. This is coupled with the squeaking issue Ive been having since my HGs were done which I am pretty sure was a boost leak
The truck had a lot of power down low more than before but when I went over 3/4 throttle the truck completely defueled and bucked real bad until I let off the gas. EGTs were also about 100 degrees cooler than normal. So I scanned codes and that is what came up. there was also weird kock/tick coming from the engine. The squeaking was also a lot less but the idle was at a lower RPM than usual
So I cleared the code and the idle immediately changed back to normal. I drove it and it seemed to be normal but the squeaking was much louder.
Also I noticed that at 3/4 throttle I was now making 25-26000 PSI of fuel rail pressure.
I have no clue what the hell is going on. Anyone have any ideas?
Old 02-18-2010, 05:48 PM
a truck
bump .
Old 02-19-2010, 07:24 AM
a truck
bump .
Old 02-20-2010, 10:47 AM
Powerstroke Techie
What is your FRP KOEO?
Old 02-20-2010, 05:52 PM
a truck
Is that a different parameter I can monitor on the dashdaq besides just the regular fuel rail pressure? Sorry that might be a really dump question. lol
Old 03-02-2010, 07:19 PM
a truck
Ok so its now thrown the code twice more since I cleared it the first time and only once did it actually throw a CEL
Any more ideas?
its goin back to the dealer to get the squeaking and stuff fixed soon
Old 03-03-2010, 04:17 AM
KOEO = Key On, Engine Off
Old 03-03-2010, 01:08 PM
a truck
Ok so the KOEO FRP is 136-145
Also it threw the code twice more today
Old 03-03-2010, 01:32 PM
Powerstroke Techie
KOEO FRP should be 0, or thereabouts. (0PSI/0.49v KOEO, according to the PC/ED manual) I have seen it ~8psi or so on some trucks.
Sounds like you might have an FRP sensor issue. PM me your VIN and the DTC and I will have a looksee if I can suggest you any info.
Old 03-22-2010, 07:02 PM
a truck
Sorry I just saw this now, I will send you a PM now
