Help. Truck won't start - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-16-2010, 03:17 PM Thread Starter
I need some help, Please. I attempted to change my fuel filters for the first time on my 08 6.4L this afternoon. I think I did the process bass ackwards. I opened the top filter first and then the bottom. Took a bath in diesel and now the truck won't start. I cycled the key like the manual says and it initially started and quit after a few seconds. Now it won't start at all. Truck has a full tank of fuel so that is not the issue. Did it lose its prime or can I take the top cap off again and retry or what? I would appreciate a call from anyone online now that has a clue what I should do. Short of you guys coming through for me it getting towed to the dealer Monday I guess. Thanks in advance.
I just tried cycling the switch again and it started and ran for about 5 seconds and dies again.
Chris
919-413-1427
Ncbosshoss is offline
post #2 of 8 Old 01-16-2010, 03:37 PM
JER-1's Avatar
Quoted: 17 Post(s)
Cool
Crack the top fuel filter cap just a touch to let the air out of the line just a little you will hear the air excape. RETIGHTEN AND THEN START IT IT should run the rest of the air out itself.
JER-1
FOR SALE $19,000
2005 F-350 DUALLY
SUPER DUTY XLT
4X4,CREW CAB 8' BED
FACTORY TOW COMAND BRAKE SYSTEM
FACTORY UPFITTER SWITCHES
EDGE EVOLOUTION 11 GAUGES BUILT IN ONE
ACCUFAB INTAKE MANIFOLD
ZOODA MOD
KITTY RAN OFF
85,600 MILES, 4.10 REAR
PREVENTIVE MAINTENENCE BELOW
SINISTER EGR DELETE
OIL COOLER REBUILD
STC FITING IN HPOP REPACED NEW UPDATED ONE
COOLANT SYSTEM FLUSH 2015
NEW CAT COOLANT 11/2015
DIESELSITES COOLANT FILTER SYSTEM
7 NEW NITTO TERRA GRAPPERS
BLUE SPRING UPGRADE
JER-1 is offline
post #3 of 8 Old 01-16-2010, 04:16 PM
Good advice. I would crack the top filter and cycle the key while a friend watches. Once you see fuel, tighten the cap and flash her up.
rollthecoal is offline
post #4 of 8 Old 01-17-2010, 06:40 AM Thread Starter
When I crack the top I don't hear anything. If I let the bowl fill with fuel with the cap slightly cracked, I can see some bubbles though. I must have a ton of air in the system. It is taking a long time to work it out but I will. I may just spring for new filters again and do it again...the right way.
Chris
post #5 of 8 Old 01-17-2010, 07:55 AM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
Chris
the filters are not the problem, you have air that needs to be worked out. It may take repeated attempts with cracking the cap etc.
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #6 of 8 Old 01-17-2010, 11:31 AM
powerstrokeNM's Avatar
same thing happened to me the first time i changed the filters. i just cycled the key on and off until it started, took 20 or 30 minutes.
powerstrokeNM is offline
post #7 of 8 Old 01-17-2010, 12:31 PM
benjamin24's Avatar
When you say cycled the key are you just doing it once? It needs to be done 6 times or more. 30 secs each time. And like said above you may have to bleed the air from the top filter.
09 Lariat Ultimate/Spartan/
AFE SS Exhaust/AFE Stage II/
Weathertech/Cervinis/Toyo/UWS
benjamin24 is offline
post #8 of 8 Old 01-17-2010, 04:41 PM Thread Starter
I appreciate all the tips. I had a lot of air in the system and all is well now. She is purring like a diesel should.
