Cruise Control? - Ford Powerstroke Diesel Forum
Old 01-11-2010, 07:28 PM
Send a message via AIM to pistolpete837
Cruise Control?
i just picked up my 08 on Friday. one thing i have noticed is that when i have the cruise engaged and hit the set - to slow down it will slow down and then hesitate and slow down alittle more and hesitate again. it will do this until i set the cruise again or take it off. i have heard about a cruise issue on these trucks i dont know if this is it?
Thanks
Peter
Old 01-12-2010, 04:52 PM
bump, any thoughts?
Old 01-13-2010, 02:58 PM
Powerstroke Techie
Mine does the same thing. I think for every time you hit the - button it drops 1mph or so.
Old 01-13-2010, 04:50 PM
ok good. I had read somewhere about the cruise catching fire? just making sure this was not it
Old 01-13-2010, 10:29 PM
The possible fire problem was on older Ford products that used a faulty cruise control deactivation switch. If you are really unlucky, the switch will leak a little brake fluid, and if it manages to short out at the same time, it could potentially cause a fire.
If you think your 2008's cruise control is weird feeling now, wait till you get a tuner installed. Each time you hit the button, it tries to accelerate by 1mph (which is fine), but it tries to accelerate that 1mph by using 100% of it's throttle. It's a very exaggerated version of what you have now.
Old 01-14-2010, 04:52 AM
Thanks for the info!
