Breaking rear housing on tranfer case!!!! - Ford Powerstroke Diesel Forum
Old 01-08-2010, 02:44 PM
I have a friend that keeps breaking the housing that the drive shaft goes into on the transfer case. (Please see picture) He's broken 4 so far they last only a month. Can anyone give me a reason why this could be happening and any ideas on how to fix it.... It's really pissing us off. Also he has a SCT tuner that is making his truck buck.....
Old 01-08-2010, 04:23 PM
the drive shaft might be out of balance
Old 01-08-2010, 05:35 PM
That's the only thing I can think. I had a bad carrier bearing causing vibration on one truck where the tail housing cracked. The other truck that i have seen with a cracked (completely disintegrated) was due to a bad u-joint.
Old 01-08-2010, 06:06 PM
Is the truck lifted? If so, how much and what size tires? Also, is it a reg cab, xcab, ccab and is it a LB or SB? Carrier bearing in stock position or lowered?
I'm wondering about overall driveshaft angle and length.....
Old 01-08-2010, 06:20 PM
yeah if its lifted that would cuase a prob if not shimmed. Also does he have vibrations while driving?
