| 6.4L Problems Forum Having Trouble? Post here |
Anti freeze leaking
The other day I was looking at my truck and noticed a wet spot on the frame on the drivers side and I popped the hood and sure enough I was low on coolant. What is wrong with it? I looked to see if I could find where it was coming from but I couldnt tell. Any help would be appreciated
do a search, its the radiator, and its common
If it's at the front, it's likely the rad.
If it's towards the firewall, it's the hose that goes between the coolant feed tube and the horizontal EGR cooler, should yours still be installed.
Its on the driver side and it just sprays it every now and then cause i can go for a while and it will be just fine and then one day it will be a little low with coolant on the hood and on everything on the driver side
Sounds more like it's puking. Need to check the HG and EGR coolers.
Is it uptop?
Is the degas bottle stained? If you take the cap off, is there white crusty crap around the neck? If you can post a pic of the area you're seeing the leak, it would be helpful. |
This guy might have a "the" problem......
Its all around the anti freeze tank and on the battery and hood
Whats "the" problem???
I had the exact same issue as you. After two trips to the dealer this is what was causing it....
(1) EGR was completely broken off (2) Head Gaskets had to be replaced |
