| 6.4L Problems Forum Having Trouble? Post here |
Drain Water Seperator Light Question
I recently bought a '08 F350 used and today the drain water seperator message came up on the dash board. I looked in the manual and it pointed me to the Powerstroke addendum, which of course didn't come in my manual package. I googled around a bit and searched hear but can't fine any information on where this thing is at and what I need to do to get it drained. Any help is appericiated
Newbie Diesel Guy Johnn9y |
It's right under your driverdoor inside the frame rail. There is a yellow 1/4 turn valve that will drain the water.
Is anyone draining this on a regular basis on just when the light comes on?
i do it about once every 2 months when I can remember. If you use good fuel, then you dont have to do it once a month as recommended.
I do it every other month and my light has never come on.
Never had the light come on. I do it every couple tanks -- never had any water though.
my drain water seperator light came on and i tried to drain it but nothing came out now what should i do i had to drive about 150 miles since it came on have i hurt my truck real bad
If you live in a cold environment, the water that you are trying to drain out will gel. If you hit it with a small blast of air, it will drain. You have to be very careful doing this, or you will get a diesel bath. Somebody recomended the canned air containers that you clean your computer with to keep pressure down. I have used shop air full power and got a bath (even though it was just a quick tap of the trigger). If you turn your pressure down to say 10-20 psi, I think it would get the job done.
6.4 is a piece of trash!! Yes, light came on over and over. Water or no water. Then truck quit. Wiring harness shorts out on 2008 models at about 50k. DO NOT BUY A TRUCK that they have to pull the cab off of to work on the engine. I am demanding a total refund...it is not right for the public to be guinea pigs for a product. Even ford is getting rid of the navistar engine. Actually the main problem is the particulate filter.
