| 6.4L Problems Forum Having Trouble? Post here |
Truck is done
Hey guys drove the truck this morning no problems once so ever, went to a mall for just over an hour, went out to start it up since its -19/-29 with wind chill. Let is run for a few minutes, went to put it in drive and it stalled out and shut off. Restarted truck no problem, but CEL comes on. Let it sit for about half an hour running, put it in drive and stumbled a bit but wouldnt go over 1500 rpm and turbo wont spool and build boost. Parked it again and noticed a little bit of oil from the exhaust pipe. So would that mean my turbo's are pooched?? at idle I could rev the engine i could see the boost gauge go up a hair but not much just barely off the zero.
No mods except for S&B intake I just put in a week ago, was going to install dpf and spartan today but weather was too cold. Last edited by jberzerker; 12-06-2009 at 04:03 PM. |
Wind chill will have zero effect on your truck.
Whats the actual air temp out there. Sounds like your fuel gelled up
are s an bs an oiled filters? i know that some times the oil can get sucked out of the filter an mess up your turbos. i don't know if this is the case though. good luck.
I really hope its just gelled fuel. Had to get it towed to the shop to warm up for the night, so we'll see what happens.
i love florida...
Truck Done CODE update
So I started the truck up this morning and it still sounded like Hell. Seemed like it was starving for air or fuel.
I pulled the codes and these are what I got. P0404 Exhaust Gas Recirculation "A" control circuit Range/Performance P042E Exhaust Gas Recirculation "A" Valve stuck open P1335 EGR Position Sensor Min/Max stop performance Sorry still pretty truck illiterate is it just the EGR that would be hooped? Last edited by jberzerker; 12-07-2009 at 05:46 AM. Reason: addition |
I have a truck with those exact codes im my bay right now.
White smoke, the whole works. It's got a blown EGR cooler, although I have not determined which one yet. The vertical one seems okay, I've got it off the truck. Horizontal off tomorrow, plus a bedplate reseal in the next bay, plus a turbo in the next bay. I love my life. |
Check your coolant level. Betcha it's down.
Would a coolant filter kit help prevent some of the problems with the EGR coolers?
