The truck is not showing any codes yet. It will sputter then die when driving. The fuel filters are changed every other oil change and I use a fuel treatment every 4th fill. Before I start tearing into the truck was hoping someone has had this issue before and can point me in the right direction.
Air filter dirty?
Did you just change the fuel filters? If so, did you bleed the system? Check for air/fuel on the fuel cooler banjo bolt. Do you hear the HFCM pump come on?
If there are no codes, seems like it should be a simple fix. Make sure you have fuel and air.
Yes. It fires right back up. I got codes today for the thermostat and fan and will be working on them today and/or Sunday.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
