TSB list? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-23-2009, 10:51 AM Thread Starter
TSB list?
Is there a post here that lists the known TSB's on the 6.4L?
Are there / have there been more TSB's than the intercooler?
2008 F250 Crew Cab 4x4
bone stock...for now
aggiephil30 is offline
post #2 of 6 Old 11-24-2009, 08:44 AM
grumpygregg's Avatar
I would like to know as well Maybe the the Mods can make a section on here that all tsb's can be listed for either just the 08's or a section that has the tsb's for all trucks by year.
2008 F350 Lariat crewcab Dually
Job 1
6.4 twin turbo
Line-X Box Liner
The rest Stock so far
grumpygregg is offline
post #3 of 6 Old 11-25-2009, 07:15 PM
Iqoair's Avatar
09-12-15 06/29/2009 A/C - Large Side To Side Temperature Differences
08B06S2 06/29/2009 Campaign - Installation Of Cooling System Venturi-Tee
09-12-1 06/29/2009 Body - Exterior Door Handle Loose
09-11-16 06/15/2009 Interior - Seat Side Trim Loose/Broken/Cracked
09-10-2 06/01/2009 Engine Controls - MIL ON/DTC's Set/Low Power/Smoke
09-9-8 05/18/2009 Engine - 6.4L Diesel Belt/Idler Pulley Chirp On Start Up
09-9-1 05/18/2009 Electrical - Trailer Wiring Fault/DTC C2806
09-8-5 05/04/2009 Cooling System - Coolant Maintenance Service Tips
09L04 04/29/2009 Campaign - Customer Vehicle Maintenance Reminder Letter
09-7-8 04/20/2009 Instruments - Compass Intermittently Loses Calibration
09-6-8 04/06/2009 Diesel Engine - Lack Of Power On Acceleration
09B08 03/31/2009 Campaign - Replacement Of Fuel Injectors
09L02 03/30/2009 Campaign - Vehicle Shimmy And Tire Inflation Pressure
09-4-1 03/09/2009 A/C - Thump Upon A/C Compressor Engagement
09-4-9 03/09/2009 Drivetrain - Vibration/Shudder On Accel With Heavy Load
08-26-4 01/05/2009 A/T - 5R100W Cold Weather Failure
08-25-7 12/22/2008 Engine Controls - ECM Update For Various Conditions
08-25-8 12/22/2008 Engine Controls - ECM Update For Various Issues
08-25-9 12/22/2008 Engine Controls - ECM Update For Various Concerns
08-25-1 12/22/2008 Diesel Engine - White Smoke In Cool Humid Conditions
08B07S2 12/15/2008 Campaign - ECM/Instrument Cluster Software Update
08-24-8 12/08/2008 Body - Sunroof Water Leaks During High Pressure Car Wash
08-24-2 12/08/2008 Wheels/Tires - Steering Wheel Nibble/Vibration
08-23-10 11/24/2008 Body - Rear Fender Marker Lamps Loose
08-19-7 09/29/2008 A/C - Slow To Cool
08-19-5 09/29/2008 Diesel Engine - Normal Random Ticking/Tapping Noises
08-16-2 08/18/2008 Engine Controls - ECM Update When Replacing Accel. Pedal
08-16-7 08/18/2008 Engine Controls - Cylinder Contribution Diagnostics
08-14-4 07/21/2008 A/C - Lack of Heat Output When Snow plowing
08-12-2 06/23/2008 Suspension - Front Suspension Noise/Bottoming Out
08-12-6 06/23/2008 Body - Rust Stains On Front Bumper
08-12-9 06/23/2008 Keyless Entry - Transmitter May Not Operate
08-12-10 06/23/2008 Power Steering - Fluid Discolored, Noise or High Effort
08-11-5 06/09/2008 Windows - Power Window Noisy
08B03 04/24/2008 Campaign - Fuel Tank Stopper Installation
08C04 04/24/2008 Recall - Fuel Tank Impact Non-Compliance
NHTSA08V191000 04/18/2008 Recall 08V191000: Fuel Tank Impact Non-Compliance
08C01 03/18/2008 Recall - Seat Back Pivot Weld Non-Compliance
08-5-14 03/17/2008 Cooling System - DTC's P0528/P0529 Set
08-5-1 03/17/2008 Audio System - Radio Won't Seek Sirius(R) Radio Channels
08-4-9 03/03/2008 Interior - Ash Tray Broken or Loose
NHTSA08V096000 02/21/2008 Recall 08V096000: Seat Back Frame Weld Defects
08-2-3 02/04/2008 Diesel Engine - Charge Air Cooler Paint Defects
07-26-5 12/24/2007 A/C - Blower Motor Inoperative or Stuck on High
07-26-2 12/24/2007 Fuel System - Intermittent No Start/Low Power/DTC P003
07-25-2 12/24/2007 Body - Rattle Noise From Tailgate
07-24-2 12/10/2007 A/C - Heater Core Gurgling Noise
07-24-4 12/10/2007 Fuel System - Water in Aft-Axle Fuel Tank
07C19S1 11/15/2007 Recall - Air Bag Replacement (Delivery Hold/Stop Sale)
NHTSA07V541000 11/14/2007 Recall 07V541000: Driver Air Bag Replacement
07-20-7 10/15/2007 Drivetrain - Moan/Groan Noises at 1,500-2,000 RPM
07-16-6 08/20/2007 Lighting - Ambulance Package Lighting issues
07S49S3 08/15/2007 Recall - PCM Update for Possible Exhaust Flame
07-14-8 07/23/2007 Engine, A/T Controls - Erratic A/T Shifting Over 50 MPH
07-12-8 06/25/2007 Body - Cab Mount Bolt Removal
07-11-5 06/11/2007 Cooling System - Vehicle Overheating (Snowplow Package)
07-11-10 06/11/2007 Steering/Brakes - Brake Pedal Kick-Back/Grabbing
07T07 06/08/2007 Campaign - Fuel Injector Replacement (Delivery Hold)
07-10-5 05/28/2007 Body - Front Door Window Scratched
07-9-1 05/14/2007 Electrical - Snowplow Lighting Issues
07-7-7 04/16/2007 Exhaust System - Exhaust Odor Inside Vehicle/Smoke
07-7-2 04/16/2007 Suspension - Rear Too High/Low for 5th Wheel Trailer
NHTSA07V139000 03/29/2007 Recall 07V139000: PCM Reprogram for Exhaust Flame
NHTSA07V140000 03/26/2007 Recall 07V140000: Battery Cable Routing
NHTSA07V139000 03/26/2007 Recall 07V139000: Potential Exhaust Flame
07S50 03/22/2007 Recall - Positive Battery Cable Routing
07-4-3 03/05/2007 Interior - Leather Wrapping On Steering Wheel Is Loose
07-4-11 03/05/2007 Exhaust System - Regeneration Functional Characteristics
This is for the 2008 6.4's.
2013 F-350 Platinum
35" Toyo Mud Terrains on stock HD rims
2.5" leveling kit
Firestone Airbags
Bilstein 5100 shocks
Iqoair is offline
post #4 of 6 Old 11-25-2009, 07:52 PM
Well how about it mods maybe you can make the above listing of tsb's or codes above in a sticky in the 6.4L Problems Forum under the 6.4 codes???? this way people who have problems can reffer to it and take the tsb ( refference number) with them when they go to the dealer. I know dealers dont search to hard for info But if you have something when you go in they might do some thing to help you!!! At least they can't say that is normal and try to brush you off Thank you Iqoair for the list Is there a place that has a more in depth explanation of each
For example "07S49S3 08/15/2007 Recall - PCM Update for Possible Exhaust Flame" reflash pcm stops regen in idle now regens only when moving above 30 mph....... that sort of info would help when tring to figure out which one applies to you situation
Job 1
6.4 twin turbo
Line-X Box Liner
post #5 of 6 Old 11-25-2009, 07:58 PM
Iqoair's Avatar
09-11-8 06/15/2009 SYNC(R) System - 911 Assist VHR Software Upgrade
09-7-9 04/20/2009 SYNC(R) System - Software Update For Various Issues
08-25-10 12/22/2008 Engine Controls - ECM Update For Various Issues
08-21-2 10/27/2008 Computers/Controls - Sync Software Programming
Here's the list for the 2009 6.4's.. Slight amount compared to the 08 models.
2013 F-350 Platinum
2.5" leveling kit
Firestone Airbags
Iqoair is offline
post #6 of 6 Old 11-30-2009, 04:52 PM
is there some where to get details for each tsb?
genedarrell is offline
