Hello fellow powerstrokers
I've run into a problem with my 08 F550 6.4. I had to remove the radiator so I disconnected both batteries and when I finished the rad and reconnected the batteries I have no power inside the cab fuse box. I do have power in the distribution box under the hood. Checked the fusible links on the passenger battery and all were good. Did a load check on both batteries and both measured good. Can't find any blown fuses, but no power in the cab fusebox.
Any thoughts or suggestions greatly appreciated.:grin:
