| 6.4L Problems Forum Having Trouble? Post here |
oil jelled up
took it to ford and they are saying we never changed the oil. The truck has 58000 miles on it. I heard that it could be cuz water got into the motor. they did have to change the radiator 2 times cuz the re call and the one they put in was broken.
any ideas lmk thanks |
Is this on a 6.4L? What type of oil and change interval were you doing?
yes its a 6.4 and we used rotila synthetic every 6000miles
A while ago, there were a couple of threads (and a big debate) about amsoil and extended drain intervals. A couple of guys running it had their oil gum up, and I think it trashed some pushrods or something, and caused a cascade of valvetrain damage. Ford even denied warranty coverage saying the oil was not approved.
Amsoil (and rotella syn) may be great oils, but something is obviously causing them to gum up in a few rare situations. The idea of fuel in the oil (from the dpf regeneration cycle) was thought to be the cause. Extended drain intervals were also in question, but you're changing every 6k which seems fine. You mention that water can be the cause of oil gumming up? I was not aware of that fact, but if true, and coolant made it into your oil, it seems like that could be a likely cause. You mention that you've had 2 radiators replaced. How quickly was that issue caught each time? Did the coolant level ever drop? If so, check out the image below about cavitation and the mixing of oil and coolant. Going out on a limb here, but it may be related to your issue, and we may have another thing to watch, for those with failed radiators. Credit to "BushPilot" on TDG.
Wow... so after the hot debate a LONG time ago on amsoil and the gelling up issue.... months down the line, the truth finally starts to come out. Coolant contamination.
Check out this thread: 6.4 F450 oil sludge - Topic Powered by Eve Community Quote:
Have you checked your coolant level? Loose some in the engine and it will definitly change the viscosity of your oil. Makes it much thicker.
ford is looking into it and doing a bunch of tests they took samples of fuel and oil. it has been sitting down there for 3 weeks and has had the ford rep and engineer has been looking at it
Definitely keep us posted!
Yeah i'm all ears on this one too. Keep us posted. |
havent heard anything just that they are still looking into it ill keep u posted
