Dealer blew up my motor Now what ? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-19-2009, 11:18 AM Thread Starter
orngpel's Avatar
Ok I know some guys on here are techs in Ford shops so mabe they can help me. I think that the dealer ship I took my truck too blew up my motor. Heres is what happened.
1. Took truck to dealer cause EGR cooler failed told the dealer that I thought it was the EGR cooler.
2.Dealer completly ignored me and did all the recalls they could on my truck before diagnosing for my complaint.These recalls included a new radiator and reflash the ecm
3.When I called the first time about the trk the service writer told me that they were doing all recalls first
4. When I called the second time the parts manager told me (because I called after hours) the truck had a ticking noise/engine noise
5. The next day I callled and talked to the service writer he said he didnt know what the noise was yet but it seemed that it was a lifter noise and mentioned the engine might have had coolant in the cylinder and tried too compress it causing damage to the valve train
6.Then they pulled the valve covers and found two rocker seized up and changed those out. No change
7.Next they pulled off the oilpan and said that there was damage to #8 cyl wallls. said they were gonna pull the motor out
8.Motor got changed out and new short block was installed
9. I picked the truck up from the dealer with the receipt looking over the receipt and I saw no oil filter listed also it stated the #8 piston was striking the counterweight on the crankshaft(bent connecting rod)
10. Contacted dealership and asked about the oil filter the service writer told me (NO I DIDNT CHANGE IT IT SLIPPED MY MIND)
11. Service writer told me too bring it up there and they would change the oil and the filter
I have too concearns with this situation 1st is the ideal that the dealer may have caused the damage to my engine by not repairing the EGR cooler prior to refilling the cooling system causing the coolant to fill up the EGR cooler and with it leaking it caused coolant to go through the exhaust and into the cylinder and then bent the connecting rod ,2nd is the fact that they didnt change the oil filter so now the new motor was contaminated with the metal shavings from the old motor what do you guys think that I should do or have the dearler ship do to make sure that my warranty will still be intact for the remander of the factory specs(100kmi). Also I tried to call Ford customer relations what a joke the totally blew me off and said that the deal is between the dealer and me that they wouldn't help me at all .What 's your guys oppinions?
orngpel is offline
post #2 of 12 Old 08-19-2009, 11:25 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
WHAT TOTAL BS. I WOULD DEMAND A NEW ENGINE AND NOT PAY A DIME!!!!!!!!!!!!!!!!!!!!
then go to a different dealer now on
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #3 of 12 Old 08-20-2009, 05:43 PM
DavidPhillips's Avatar
How can you forget to change an oil filter when it is a different engine?
Not sure it would contaminate the oil though. Did you keep the old filter or check it?
All my touring photos. (except the two massive trips in 2011-soon to be posted eventually)
-david
/ 2011 F250 4x2 Crew Cab /
Replaced "The Beast" 6.4L with 75,000 miles. Hated to see it go.
DavidPhillips is offline
post #4 of 12 Old 08-20-2009, 05:49 PM
back in the saddle
shu873's Avatar
I don't get it...
If they replaced the short block they would have put all new oil in the motor. Even if it was the original filter it would still have trapped any contaminants, right? Stupid mistake from the dealership, but I doubt it would cause you any troubles down the road. That being said I would replace the filter if you haven't done so already.
Also sounds like you need to find a different dealership for your service needs. They are not all created equal.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #5 of 12 Old 08-21-2009, 07:34 PM Thread Starter
orngpel's Avatar
idk
I dont know why they didnt change it I got the trk at the end of shift on Saturday and was reading over the invoice and noticed that there wasnt a oil filter on there,So I called the service manager and he told me it slipped his mind what an idiot anyway I went there thursday and they changed the oil and the filter and the fuel filter no charge but I am still concearned with th engine because I had to drive like 300 miles with the old filter. Also I was on my way to the dealer and the darn brake caliper tied up so I had to have it towed to another dealer to get that fixed because THE GRREAT FORD ROADSIDE ASSISTANCE wouldnt tow it the extra 12miles to the original dealer it was at........b.s. I give up any body wanna buy a truck I want my 7.3 back I know its not the trucks fault but atleast I could work on it without pulling the cab ooh and i am serious about selling the truck .
orngpel is offline
post #6 of 12 Old 09-03-2009, 05:05 PM
Send a message via Yahoo to skipnay
I would ask them for the oil change, oil filter, and come new with the new motor they are going to put in.
skipnay is offline
post #7 of 12 Old 09-03-2009, 05:13 PM
youngstroker's Avatar
how much for the truck?
03 super cab, 6.0l, short bed, 4x4, muffler and cat delete, 285/75R16 dunlop rover m/t, SCT x3 tuned by kem performance, auto meter gauges, cfm intake manifold.
youngstroker is offline
post #8 of 12 Old 09-03-2009, 05:16 PM
duct tape & zip ties
bigcountrysg's Avatar
According to what your saying is they used a shortblock.
Ok in terms of a shortblock, that is an engine block, crank, and pistons. You use your heads you have and everything else that is on the old engine. Then the old short block goes back for core charge. Nothing wrong with using a shortblock replacement.
Change your oil, and drive the truck. If anything comes up again with in the warranty then take it to a different dealer.
As for who or what caused the damage to the engine. Well it is under warranty and did not cost you money to repair. All recalls are completed now.
As for the use of an old oil filter. Well if the filter did its job then there should be no concerned about contamination to the oil. Because all metal shavings should have been trapped by the filter.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #9 of 12 Old 09-04-2009, 05:35 PM Thread Starter
orngpel's Avatar
Angry
Well that is a HUGE IF for a $50k truck tht I still have to pay for,for the next four years and that the warranty is almost half gone already . I think the dealer should have put a whole engine in the truck because when I took it to them it didnt have any engine noise and instead of listening to me and changing the EGR cooler like I told them they decided that they were smarter than me and did recalls and changed the radiator ,when they did that the refilled the cooling system including the old damaged Egr cooler and it leaked into the exhaust system and right through the open exhaust valve and into the cylinder then they tried to start it and hydrolocked it and thats why I got the motor inthe first place neglegance on the dealers part................. B.S. and I dont think that it was very smart for them or anyone to reuse a oil filter ever especially on someone elses truck , weather it worked or not is not the issue it is simply the principal of the matter Also if I hadn't told them they didnt change the filter what do you think the chances of them calling me and telling me that they forgot are I say slim and none
orngpel is offline
post #10 of 12 Old 09-08-2009, 11:36 AM
I agree with you 100% but chances are nothing will come about it with your dealer and you. You could get a lawyer to write a nasty letter, with that said you will spend about about 500-2k and get the same results. just my
2009 f250 6.4, Harley, 8" rize kit, rize traction bars, 38x15.5 kumho mt, 20x12 Weld Dune wheels, Icon adj. trackbar, 1-piece custom driveshaft. H&S minnimax, 5" downpipe back exhaust afe intake
palady6.4 is offline
