MAP sensor problems - Ford Powerstroke Diesel Forum
Old 08-02-2009, 10:17 AM
MAP sensor problems
Hey guys I got some issues with my new truck and I dont want to have to return to stock if I dont have to. I was at a horse show and got some codes on the truck one day. The codes were:
P0106 - Manifold Absolute Pressure/BARO Sensor Range/Performance - This diagnostic compares MAP and BP pessures at idle conditions, when they should be within a specified range. - This error is set if the MAP sensor reading is above or below the thresholds for a predetermined period of time.
P2262 - Turbocharger/Supercharger Boost Pressure Not Detected - Mechanical
This error occurs if the MAP sensor readings are below a calibrated value for a predetermined amount of time. - Engine speed and torque based table >30 sec - System error, CAC hose, MAP sensor plugged...
Im guessing the map sensor is going bad. The truck got a CEL light and lost power. I was not acually driving the truck when It happend so I can describe what happend to detail. Has anyone had a map sensor issue on there 6.4 Also does anyone know where the map sensor is located and where is the best place to purchase one. If yall dont think its the map sensor please let me know..... Thanks
