Black Smoke - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-16-2009, 05:28 AM Thread Starter
Talking Black Smoke
I am new to owning a Powerstroke 6.4. While away in PEI while passin g another truck the truck hesitated blew black smoke and than took off. The next with the 5ver on the truck slowing down to make right turn and than accelerating blew black smoke. The truck is stock. Is this a problem?
easy four is offline
post #2 of 8 Old 07-16-2009, 06:21 AM
My F350 smoked stock all the time. THe DPF was *not* cracked, but it still smoked like a locomotive every time you hit the gas. My F450 virtually never smokes. Even when you really hit it, it will give only the faintest bit of black smoke.
Every truck is different. Even when they are the same year, same calibration, same engine, etc. I wouldn't worry about it unless it gets worse.
Eli Benson - EMT, Ambulance Mechanic
'08 F350 Dually KR - Spartan'd
'07 F250 CC SB 4x4 XLT - SCT /w Innovative Tunes
4 '09 & '10 E350 6.0l ambulances
1 '08 Duramax 6.6 (LMM) van ambulance
elibenson is offline
post #3 of 8 Old 07-16-2009, 06:59 AM
Shinny's Avatar
Was it in regen? My dealership told me that I might see alot of different color smoke while in regen and towing. I haven't seen any though.
2008
F250 SuperDuty FX4 Crew Cab Short bed Silver Metallic Dark Shadow Grey Job 1
Extang Trifecta Bed Cover
Spray in bed liner
High Idle Mod
Second Radiator
Second EGR Valve
100% Stock
Towing a 30' Trail Cruiser Travel Trailer
Shinny is offline
post #4 of 8 Old 07-16-2009, 12:14 PM
DavidPhillips's Avatar
Mine never smokes except when it had the bad charge air cooler and then it was white smoke. It only did it if it had been raining. TSB 08-25-1.
Did you buy it new? How many miles on it now?
All my touring photos. (except the two massive trips in 2011-soon to be posted eventually)
-david
/ 2011 F250 4x2 Crew Cab /
Replaced "The Beast" 6.4L with 75,000 miles. Hated to see it go.
DavidPhillips is offline
post #5 of 8 Old 07-16-2009, 07:11 PM Thread Starter
Talking Black Smoke
No the truck was not in regen. It is a2008 F350 XLT Crew bought
new with 14000 k on it
Thanks
post #6 of 8 Old 07-16-2009, 07:42 PM
maybe cause it's new?....
hammett88 is offline
post #7 of 8 Old 07-16-2009, 07:57 PM
builtnotbought's Avatar
Did you enjoy the concert ?
1999 F-250 SUPERDUTY ZF6
37'' Toyo MT - DIY Intake - 2.2K Mod - 4'' Turbo Back SS - GTP38R - And Lots more.
'' My Lug Nuts Require More Torque Than Your Honda Makes ''
builtnotbought is offline
post #8 of 8 Old 07-17-2009, 04:47 AM
I don't believe it's right but the people that have the problem often get told it's normal.
-david
