Is this normal with the 275
When im cruising between 45-55 mph I can feel the truck surging a bit. RPM's dont move and niether does the speed, it just feels like it's speeding up for a brief second then cuts off. I believe its the torque converter trying to lock. If i get into it a bit the TC locks up and it doesn't do it any more. It's kind of a pain since it's 50 mph almost every were around here and i can't run 60 all the time.
Monitor your rail pressure and see what it does at that point. If it jumps up and down then you will know its surging. Sometimes if your converter is close to locking up and you dont continue in the throttle it will kind of jump a little, but I think thats pretty normal under cruising conditions. But like I said, monitor the fuel rail pressure, that should tell you
The rail pressure seems to be pretty steady but so does the tc slip.. I dunno?
I've only been running the tune for a couple days maybe it just needs some time!
Thats what i was thinking, just wanted to see if anyone else was experiencing the same thing.. I do love the tune though!! Just feel bad for my mud grapplers, looks like i'll be ordering some 38's sooner than i thought!!!
I can't even imagine! I need to get my hands on it before these tires are toast, so i dont burn up the new ones right away!
![]() Will they hold 50+psi to keep the dang light off for the pressure sensors? |
Mine are a 80 max psi tire and I keep 65 in both with no issues. I have about 18,000 miles on mine with the Spartan
