Mini maxx question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-05-2014, 12:54 PM Thread Starter
Mini maxx question
Installed and now I keep getting a u0073 code. Any ideas?
SKEETERMAN03 is offline
post #2 of 7 Old 05-05-2014, 01:35 PM
Quoted: 48 Post(s)
a little more background info would be great
it's a communication code. I would check the connectors at the ECM and the big connectors in the driver's fender well
drunk on diesel is offline
post #3 of 7 Old 05-05-2014, 02:13 PM Thread Starter
Check both. This did not happen till I installed the tuner.
post #4 of 7 Old 05-05-2014, 04:38 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
h&S had some problems with the obd2 block and hdmi cables. mine did it but it was a more serious problem and wouldnt let the truck start and ended up being the brake control module shorted out shutting the computer down to save it from damage. check your hdmi cord for cuts. id call h&S tomorrow and tell them what happened and they should send you a replacement hdmi and obd2 block. if that dont fix it there is a short somewhere causing the can/bus system to shut down
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #5 of 7 Old 05-05-2014, 07:05 PM Thread Starter
Ya truck will not start till I clear the code.
post #6 of 7 Old 05-06-2014, 04:28 AM
Bingo ^^^^^
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #7 of 7 Old 05-06-2014, 04:34 AM
Quoted: 48 Post(s)
literally just solved this same problem on a truck this week..
it would scan/read just fine with factory tune in it
with an SCT loaded it would high idle and go into limp.
with an H&S loaded, it would cycle the VGT, engage the fan clutch, and pop a U0073 and wouldn't restart until the code was cleared
the truck had had the cab off and one of the main wiring connectors in the driver's fender well wasn't seated all the way. reseated that connector, and it's been golden since
