H&S xrt pro - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-03-2014, 01:19 PM Thread Starter
H&S xrt pro
Guy selling xrt on criaglist how do I know if
It's a dpf delete xrt pro? He sent me a picture of
The tune version is 6.4 28 hd300
How can I tell if it's a dpf delete ?
Thanks guys
Hickman 6.4 is offline
post #2 of 4 Old 05-03-2014, 04:56 PM
TD-5's Avatar
Quoted: 3 Post(s)
XRT PRO Pt # 109005 is the old delete capable tuner,
XRT PRO Pt # 209006 is the newer street tuner with USA software-WILL NOT ALLOW DELETES
XRT PRO Pt# 309016 is the newer street tuner with international software- Will ALLOW emissions deletes
6.4.28 is the latest firmware installed in the tuner & dated August 19 2013. This may be the last update the previous owner has installed, or if its never been updated ,then it was most likely sold new sometime after this date & is a street tuner.
What ever it is, If you decide to purchase it, make absolutely sure the previous owner has returned the truck it was on, back to OEM stock & unlocked the tuner from that trucks VIN #. If it is NOT unlocked from the previous trucks VIN # then it is useless to you.
2010 F350 KR CCLB, mini max, H&S pyro kit, ARP studs, II 71/59 billet turbos, RCD ported intake, ceramic BD 6.0 exh manifolds, stainless uppipes, SDP 4" ceramic downpipe, 5" MBRP stainless, sinister egr delete with intake elbow, 3" CAC cold side pipe, BD boots, AFE custom air intake, AirdogII, Mann&Hummel CCV filter, 4.10 Yukon locker rear, Eaton TrueTrac front, Coolant filter
TD-5 is offline
post #3 of 4 Old 05-03-2014, 05:04 PM
WoodBoy's Avatar
XRT Pro 109006 is also delete capable. You can simply plug it in, go to the settings, vehicle info, and then look where it says Download and it will say Download: Installed or Not Installed. Obviously you are hoping to see Not installed.. A Vin number may pop up and/or it may say a vehicle such as 07.5-09 dodge 6.7 or something but it is irrelevant if it says not installed.
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #4 of 4 Old 05-03-2014, 05:57 PM Thread Starter
So the 30916 xrt street tuner will alow dpf
Delete?
