Sinister EGR Delete and Coolant Filter Installs Review - Ford Powerstroke Diesel Forum
 2Likes
  • 2 Post By JSBucinski
post #1 of 7 Old 04-21-2014, 07:42 AM Thread Starter
JSBucinski's Avatar
Hey guys, I knocked out my EGR delete and coolant filter system this weekend on my truck. I just wanted to share a few things and thoughts for everything that may go down this route or if they are deciding between brands.
1.) Sinister EGR Delete.
I didnt really run into any problems with this kit, most people complain about stripping the exhaust flange bolts or what not. A few things i did to avoid this. First when i started the project I sprayed those bolts with penetrating oil and a few times after that as i went. Second i brought my buddy that is Air Winger Mech, Thirdly i had recently spent a small fortune to have the top half of my motor replaced after a gross over rev. So when i stop by the dealership i made sure the mech had taken everything off that i was going to so it was nice and broken loose for me. Some people reccomend that you take out the inner fender well to do this install. I didnt have to and didnt see any reason too. Everything from Sinister fit nice and snug how it was supposed to and sealed up correctly. The instructions were very detailed and easy to follow. The only snag i ran into was that when reconnecting hoses it was telling me to splice a certain line where i already had a T connector. I'm pretty sure this is due to Ford updating our set up when all the radiators were leaking. It wasnt hard to figure out what to do at all though. You just take out the T and plug the line running voerthe radiator directly to the overflow tank. The only critque i really have for this kit is that it will tell you to (re torque bolts to factory specs) can we please just list them right there.
For H&S users just make sure to retune truck to the MED or HD tune after or you will throw codes.
2.) The Sinister coolant filtration system.
This kit is very easy and straight forward. You will need a breaker bar to loosen up those transmission cross member bolts! Kit bolts up and everything fits very easy. The mounting location is nice and safe for the filter. I love that the have two ball valves there. No leaking of coolant during filter changes and if something breaks you can always turn both of them off and your truck will still run. I have heard other people complain about how other companies kits didnt give them long enough hoses. I did not have this problem at all. Sinister was nice enough to give me a few inches at that!
All in all both installs went really nice and easy. I am very happy with both kits. As i purchase more products i will certainly be checking with Sinister to see if they have what i want first. +1 to Sinister for making there parts blue because my truck is blue!
SSgt. Bucinski USMC
2008 Ford F250
6.4 Powerstroke Turbo Diesel
"My reputation precedes me."
JSBucinski is offline
post #2 of 7 Old 04-21-2014, 08:30 AM
Thank you for the review!
blanco.customs is offline
post #3 of 7 Old 04-22-2014, 11:54 AM Thread Starter
JSBucinski's Avatar
Further more impresed with Sinister. I just got a follow up call from Sinister on one of my parts that was back ordered (not their product). Will be shipping out soon and they are throwing in some free stickers and koozies for the wait!! I get excited about little things but being in sales myself i can appreciate good customer service!
SSgt. Bucinski USMC
2008 Ford F250
post #4 of 7 Old 04-23-2014, 03:58 AM
muntu's Avatar
curious about your over rev....what happened...what got screwed up and how high did the rpm go ?
2008 6.4 job3 F250 3:55 gears 10K gvw silver stretchcab 8ft box.timbrens and goosenek hitch.51 gal aux tank.
muntu is offline
post #5 of 7 Old 04-23-2014, 06:53 AM Thread Starter
JSBucinski's Avatar
Here check out the thread I made of it. Even has some pics. Did I run it that hard?
SSgt. Bucinski USMC
2008 Ford F250
post #6 of 7 Old 04-25-2014, 06:14 PM
Chorgey's Avatar
My only suggestion for the coolant filter would be to use something better than worm gear clamps where the T goes. Despite being as tight as I could make them, I ended up getting a small drip of coolant that ran down the hose and dripped on my alternator. Ended up frying it and was a 4 day wait to get a replacement. That's just my own awful luck though. Better safe than sorry for the rest of you guys though...
Chorgey is offline
post #7 of 7 Old 04-25-2014, 10:26 PM
B585Ford's Avatar
Great right up, thanks.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
