Torque android app - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-18-2014, 05:36 PM Thread Starter
Sam Hain's Avatar
Torque android app
I bought an obd bluetooth scanner and thought these trucks had a egt probe already but I can't seem to get torque app to read egts. It found coolant temp, trans temp, boost, and RP. Any ideas?
Sam Hain is offline
post #2 of 13 Old 04-18-2014, 06:13 PM
Hunter of Trolls
drewactual's Avatar
Quoted: 57 Post(s)
Torquey is a good ap... But its primarily for gassers ... Gassers don't care about egts... Your truck hasten, though..
drewactual is offline
post #3 of 13 Old 04-18-2014, 06:37 PM
Yeah, like I said, barebones monitoring system. It works to hold me over til I get an edge.
2008 F350 RCLB, 2011 bed and wheels
SCT tuned, 4" straight pipe exhaust
Sideswipe505 is offline
post #4 of 13 Old 04-19-2014, 05:08 AM Thread Starter
Sam Hain's Avatar
The app has egt 1 and 2 but they don't work. Doesn't these trucks have and egt probe?
Sam Hain is offline
post #5 of 13 Old 04-19-2014, 12:39 PM
They do, on my spartan it's listed as EGRTA. It's basically pre turbo EGT. Where that probe is located exactly I'm not sure. But if I had to guess I'd say it's near the back by the horizontal EGR cooler.
2008 CCSB Lariat
Spartan 250EL
Flo-Pro 5" DP back
S&B Intake
Sinister EGR Delete
Kris 6.4 is offline
post #6 of 13 Old 04-19-2014, 12:40 PM
Yeah but you need to find the correct PID for it and input it into the advanced settings. I don't haul much so I haven't been overly worried about it.
post #7 of 13 Old 04-19-2014, 04:55 PM
08stroker250's Avatar
The pre-turbo EGT sensor is the Exhaust Gas Recirculation Temp Sensor A (EGRTA).
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #8 of 13 Old 10-21-2014, 09:46 AM
ckrueg's Avatar
Quoted: 3 Post(s)
The pid is 22096d. I set the equation to convert to farinheit
ckrueg is offline
post #9 of 13 Old 10-29-2014, 11:03 AM
Bump To Pass!!
toren302's Avatar
Quoted: 1610 Post(s)
Can you elaborate on this^^^
I cant get the EGT sensor to work at all with the torque app. What did you set the equation up at. Actually if you could post what the entire pid is set at that would be great.
toren302 is offline
post #10 of 13 Old 11-11-2014, 07:28 PM
This is what I have come up with so far by experimentation.
I would appreciate any help testing and completing this list.
6.4 Powerstroke PIDs for Torque Pro
Testing Complete: Yes
PID: 2209d4
Long Name: 6.4 Accelerator Pedal Position
Short Name: Pedal
Min.: 0
Max.: 100
Scale: x1
Units: %
Equation: A/2
Header: Auto
Notes:
PID: 2216a8
Long Name: 6.4 Ambient Air Temp.
Short Name: Amb. Air
Min.: 0
Max.: 120
Scale: x1
Units: F
Equation: (A*256)+B
Header: Auto
Notes:
PID: 221172
Long Name: 6.4 Battery Voltage
Short Name: Battery
Min.: 0
Max.: 100
Scale: x1
Units: Volts
Equation: A/16
Header: Auto
Notes:
Testing Complete: No
PID: 221624
Long Name: 6.4 Cylinder Head Temp.
Short Name: Cyl. Head
Min.: 0
Max.: 100
Scale: x1
Units: F
Equation: (((A*256)+B)*1.999)+32
Header: Auto
Notes:
PID: 22fd8a
Long Name: 6.4 Dist. Since Last Compl. Regen
Short Name: DSLCR
Min.: 0
Max.: 10000
Scale: x1
Units: Miles
Equation: (((A*256)+B/10)*0.621371192
Header: Auto
Notes: This is probably not the correct PID
Testing Complete: ?
PID: 22116c
Long Name: 6.4 DPF Back Pressure
Short Name: DPF BP
Min.: 0
Max.: 100
Scale: x1
Units: psi
Equation: (((A*256)+B)*0.03625)*0.145
Header: Auto
Notes: Equation? Sensor spec range is 0-12 psi.
I added *0.145 to convert from kPa to psi
PID: 220966
Long Name: 6.4 DPF Regen Status
Short Name: Regen
Min.: 0
Max.: 128
Scale: x1
Units: on/off
Equation: A/128
Header: Auto
Notes: Result will be a 0 or a 1
PID: 22c974
Long Name: 6.4 DPF Soot Load
Short Name: DPF Soot
Min.: 0
Max.: 100
Scale: x1
Units: #
Equation: (((A*256)+B)+8192)/1000
Header: Auto
Notes: Use this raw number to determine your range then
create another PID for percentage (see next PID).
PID: 22c974
Long Name: 6.4 DPF Soot Load Percentage
Short Name: DPF Soot %
Min.: 0
Max.: 100
Scale: x1
Units: #
Equation: (((((A*256)+B)+8192)/1000)-45)/(57-45)*100
Header: Auto
Notes: My Soot Load range is about 45 to 57.
So, % Soot = ((Soot Load)-45)/(57-45)*100
PID: 22115f
Long Name: 6.4 Turbo Inlet Temp. (EGRT1 or A)
Short Name: Turbo In
Min.: 0
Max.: 1800
Scale: x1
Units: F
Equation: ((((A*256)+B)/10)-40)*(9/5)+32
Header: Auto
Notes: Equation?
PID: 221161
Long Name: 6.4 EGR Inlet Temp. (EGRT2 or B)
Short Name: EGR In
Min.: 0
Max.: 600
Scale: x1
Units: F
Header: Auto
Notes: Equation?
PID: 2209fe
Long Name: 6.4 EGR Valve Position (% open)
Short Name: EGR %
Min.: 0
Max.: 100
Scale: x1
Units: %
Equation: ((A*256)+B)*0.003052
Header: Auto
Notes: Equation?
PID: 220991
Long Name: 6.4 EGT11 Post Turbo (pre DOC) Temp.
Short Name: Post Turbo
Min.: 0
Max.: 1800
Scale: x1
Units: F
Equation: (((A*256)+B)*(9/5))-40
Header: Auto
Notes:
PID: 220992
Long Name: 6.4 EGT12 Post DOC (pre DPF) Temp.
Short Name: Post DOC
Min.: 0
Max.: 1800
Scale: x1
Units: F
Header:
Notes:
PID: 221171
Long Name: 6.4 EGT13 Post DPF Temp.
Short Name: Post DPF
Min.: 0
Max.: 1800
Scale: x1
Units: F
Header: Auto
Notes:
PID: 0105
Long Name: 6.4 Engine Coolant Temp.
Short Name: Coolant
Min.: 0
Max.: 300
Scale: x1
Units: F
Equation: ((A-40)*(9/5))+32
Header: TCM
Notes:
PID: 221310
Long Name: 6.4 Engine Oil Temp.
Short Name: Eng. Oil
Min.: 0
Max.: 300
Scale: x1
Units: F
Equation: ((((A*256)+B)/100)-40)*(9/5)+32
Header: Auto
Notes:
Testing Complete: ?
PID: 221445
Long Name: 6.4 Exhaust (manifold) Back Pressure
Short Name: Exh. BP
Min.: 0
Max.: 100
Scale: x1
Units: psi
Equation: (((A*256)+B)*0.03625)-BARO()
Header: Auto
Notes: Equation? Sensor spec range is 4-90 psi.
PID: 221674
Long Name: 6.4 Transmission Fluid Temp.
Short Name: Trans. Fl.
Min.: 0
Max.: 300
Scale: x1
Units: F
Equation: ((A*256)+B)/8
Header: TCM
Notes:
PID: 221440
Long Name: 6.4 Turbo Boost Pressure
Short Name: Boost
Min.: 0
Max.: 40
Scale: x1
Units: psi
Header: Auto
Notes:
oliver972 is offline
