SCT 3015 not powering on - Ford Powerstroke Diesel Forum
post #1 of 1 Old 04-17-2014, 01:43 PM Thread Starter
I have a 2008 F250 SRW 4x4. I bought an SCT 3015 about two months ago and installed it. I has the tunes that have the DPF and EGR deleted already in the tuner.
It was working fine until this week when I was going to change the tune and the tuner did not power on. I plugged it into my Dad's F250 and the tuner powers on. So I thought that it could be my OBDII port not working. So I plugged in my OBDII scanner and it worked fine. So it seems that the SCT 3015 that I have does not work with my truck anymore only. I checked the Fuses and none of them were blown. I disconnected the batteries and reconnected them and still nothing. I called SCT tech support and they suggested that there was probably a bad ground.
Of note, I took my truck to the stealership to get the A/C fixed. The last time I plugged in the tuner to the OBDII port was before that. Anybody knows what's wrong? Thanks
evildocrsx is offline
