do I need to change out the torque converter? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-17-2014, 10:54 AM Thread Starter
I have done a lot of reading and with my set up i know ive done something with the hp on internal parts I dont have ac0cess to a dyno so I dont know how much. I am running a spartan 250ll right now but was on the 300el and it felt slippy when i hammered it.
My question is should I be looking at getting a better torque converter in it to run the 300 and 310.the 350 is off limits til i do but any sugestions?
08 F350 XLT LONG BED toyo at2 35x12.5x18, rancho 4" lift pro comp dual stering stabilizer, spectra radiator, banks ram air, flo pro egr delete,cac pipe, 4" down pipe to 5" exhaust 6" tip arp head stud stage 1 valve springs, stage 1 push rods, coated international pistons,
next: AIR DOG 165, 71mm atmo turbo
acbydennis is offline
post #2 of 13 Old 04-17-2014, 12:29 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I will be going with a precision industries torque converter in the 1600 stall.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 13 Old 04-17-2014, 12:44 PM
WoodBoy's Avatar
Monitor your tc slippage with the tc locked at WOT.. You don't want it over 10ish
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #4 of 13 Old 04-17-2014, 05:45 PM
Quoted: 20 Post(s)
let me know if i can help, im a dpc dealer. fantastic converter that ran flawless at 775 rwhp.
SCT X4 Off-Road Sale ! $749 for 6.4 or 6.7 up to 2015
Authorized Distributor For :
H&S Motorsports
BMF Wheels
Icon Suspension
No Limit Fabrication
Click Banner Below for All Things No Limit Fab.
800-581-8986
bigrpowr is offline
The Following User Says Thank You to bigrpowr For This Useful Post:
acbydennis (04-18-2014)
post #5 of 13 Old 04-18-2014, 09:54 AM
08stroker250's Avatar
0-10 RPM is error.
Anything above that I'm not even sure at this point. Both my SunCoast converter and RCD converter would see over 10 RPM with the converter locked. Cruising speed, it would always jump around below 10. WOT, I would see 40-50 RPM at times. Never saw the 200+ I started seeing with my stock converter though.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #6 of 13 Old 04-18-2014, 10:18 AM
WoodBoy's Avatar
Yeah I knew it was just error readings in the signal but I thought on a stock convertor once it started getting actual slip readings above 10 that it would work it's way out.
WoodBoy is offline
post #7 of 13 Old 04-18-2014, 11:03 AM
Wasn't the case for me. Mine was still holding up when it would see 200+ at WOT.
Jeff Dodd
post #8 of 13 Old 04-18-2014, 11:07 AM
have you done a relearn on the trans after switching tunes?
2006 250 sc, custom tunes from innovative, 4inch turbo back mbrp.
princetontigers is offline
post #9 of 13 Old 04-18-2014, 05:30 PM Thread Starter
I didnt notice much slippage at 310tune but with winter coming I turned it down to the 275 to stop the juppyness so I could keep it on the icy roads. now that its warmer I noticed it. I programmed it and took the tuner out before the wife saw how to program it.She swears that I did a wheelie in it)
I just read from Spartan that its good to reprogram a tune every once in awhile so I'm gonna reload the summer smoke tune, and have some tuner cars chase me....... I REALLY WANT TO TRY THE 350 TUNE!!!!! BAD BUT IM PRETTY SURE ILL NEED MORE THAN A TQ CONVERTER IF I TRY IT PREMATURELY
post #10 of 13 Old 04-18-2014, 06:12 PM
WoodBoy's Avatar
The 310 is a faster tune
WoodBoy is offline
