Q's about AirdogII - Ford Powerstroke Diesel Forum
post #1 of 21 Old 04-10-2014, 09:31 AM Thread Starter
JSBucinski's Avatar
Q's about AirdogII
I've spent the majority of the work day utilizing the search button and installation instructions, but and ended up with a few specific questions. I have pretty much decided to go with the AirdogII because it removes the OEM filter and pump. I want to do this kit for reliatbility and not power. I have a dpf delete/tuner, intake, headstuds, and upgraded pushrods. I plan on purchasing the egr delete / cac / intake elbow kit along with my AirdogII. I dont plan on adding any more power just continuing to bullet proof my truck. So here are my questions.
1.) Do you have to drop the tank or remove the bed for the II? I have seen both answers.
2.) The adjustable regulator preset at 10psi. What do i need to know about this? What do you have yours set to and why? Why do they preset at 10? If you want to throw a wall of text at me with this one i'd appreciate it.
3.)Where do you bleed the air out of the line from once you are done and how do you go about this? I did not care for the installation's explanation. Free male unspoken bond head nod to who ever posts a picture of where you bleed the line from.
SSgt. Bucinski USMC
2008 Ford F250
6.4 Powerstroke Turbo Diesel
"My reputation precedes me."
JSBucinski is offline
post #2 of 21 Old 04-10-2014, 10:18 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 57 Post(s)
1. No... use your phone's camera and snap a shot of the tank's basket.. orient yourself to the passenger side of the tank, head toward rear, and you can reach up and snatch up the quick releases to disconnect the OE, and plug up the AD..
2. preset is what you're looking for.. if you ever add any fuel adders, you may possibly need to add more lift pressure.. until then, you're fine.
3. there is no need to bleed... but.. you may need to cycle the pump several times over, just as you would if you swapped filters on the OE HMFC, and as you will do with the AD when you swap filters... either turn ignition off and back on (no start), Or, push the button under the passenger front door jam labeled 'fuel cut off'... either way, it primes the pump..
drewactual is offline
post #3 of 21 Old 04-10-2014, 10:19 AM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
1. Either. Unless you have really little hands and long arms. I dropped my tank just a few inches to get enough access.
2. I just left mine at the preset. Haven't read anything to tell me otherwise.
3. I didn't really bleed mine. Just cycled the key like 20 times. Same thing I do when I replace fuel filters.
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #4 of 21 Old 04-10-2014, 10:20 AM
STANGMAN893's Avatar
I have now installed 4 now and would drop the tank. First one I did cab off and tank in and was tight but doable. Last ones dropped the tank and was easier to get to. I did not touch the regulator whatsoever and bled the fuel into a bucket after the pump and at the engine and started first turn. The only thing I really learned was use the splices to shorten the hoses for a cleaner route and I eliminated the spacer block that they gave to keep it away from the transfer case.
STANGMAN893 is offline
post #5 of 21 Old 04-10-2014, 10:23 AM
Last one used a trans jack and lowered it a bit.
post #6 of 21 Old 04-10-2014, 10:31 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 57 Post(s)
I am not a little dude- and my arms are by no means small... the trick is getting a look at the basket and identifying what is what and where it is... after that, you can do it by feel alone.. and reach up to the basket from the passenger side........
I've done three... I dropped the tank on the first one.. I didn't drop the tank on the second one.. I dropped it on the third one because I installed a sump on the tank..
a matter of fact, I HIGHLY recommend installing a sump and disregarding the top connection altogether..
post #7 of 21 Old 04-10-2014, 10:43 AM Thread Starter
JSBucinski's Avatar
All good information. Thank you guys. Why did you remove the spacer block?
I am a thin 6foot so the reach wont be bad for me.
SSgt. Bucinski USMC
2008 Ford F250
post #8 of 21 Old 04-10-2014, 10:49 AM
The last were 4 door short bed and the transfer case was close to the pump and caused the hose to be too close and kink a bit. Removed the spacer and had a straight shot to the front from there.
post #9 of 21 Old 04-10-2014, 10:55 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 57 Post(s)
I'm telling you straight, do yourself this favor:
it will never be easier than it is with the tank on the ground...
post #10 of 21 Old 04-10-2014, 02:27 PM Thread Starter
JSBucinski's Avatar
any good advice as to dropping the tank in gagrage with some rpetty simple tooks?
SSgt. Bucinski USMC
2008 Ford F250
