Bosch oil filter - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-09-2014, 07:40 PM Thread Starter
thomas5853's Avatar
Send a message via AIM to thomas5853
Bosch oil filter
Attached is a picture from the top of a Bosch premium filter and a Motorcraft. Will the little pressure ball cause any issues on the Bosch filter?
2010 F350 Lariat DRW FX4
thomas5853 is offline
post #2 of 3 Old 04-09-2014, 08:53 PM
B585Ford's Avatar
Without seeing the rest of the filter, I cant tell why it is there instead of solid plastic piece. In any case, unless you have seen several guys running these on a 6.4 for a lot of miles without any issues, I would stick with the OEM filter. The Bosch may be better than Ford's but it may not be designed specifically to work on a 6.4 so it could be worse. Since there haven't been many issues with the Ford filter, taking a chance on an unknown is not worth it IMO.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #3 of 3 Old 04-09-2014, 09:53 PM Thread Starter
thomas5853's Avatar
Thanks for your input. I was at autozone picking out some Stanadyne lubricating additive and was looking at what stuff they have. The Bosch was only $16.99. So I thought it was weird and never heard about anyone using it. The lower part looked the same as the Ford filter. Autozone added some more diesel products in one corner. Plus I was looking at what places to get ELC coolant. When I am up for my next oil change, I was planning to do a coolant flush at the same time.
