Losing MPG's..... Help!!!! - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 14 Old 04-08-2014, 09:36 AM Thread Starter
It seems since I've been having my truck, the MPG have been slowing declining, when I drove the truck home from buying it used, it said 15 on the dash But since than its been getting worst, I was down to 10.3 So I added & H&S tuner no change in any setting, And I have been driving it pretty easy, Ok Last weekend I added An No limits CAI now I'm down to 10.2 Its got 35's and a 3" lift but other than what I mentioned that's it. Will changing out the exhaust make that much of an improvement Its gotta help RIGHT!!!! What else can I do for MPG's? Besides parking the thing. Dang
RichardT is offline
post #2 of 14 Old 04-08-2014, 09:47 AM
Delete the dpf and make sure you have a tuner capable of doing that, delete the EGR, and when you tune your truck run one of the higher hp tunes like the 300HD The timing and fuel maps with those are the most efficient. Keep your foot out of it and you'll see an improvement. The 6.4 will never get great mpg's but with the mods listed along with the ones you have you could expect 15 to 17 mpg's. Also the mpg monitor on the dash is notoriously incorrect. Try doing some hand calculations to get a true mpg number.
2008 CCSB Lariat
Spartan 250EL
Flo-Pro 5" DP back
S&B Intake
Sinister EGR Delete
Kris 6.4 is offline
post #3 of 14 Old 04-08-2014, 11:04 AM Thread Starter
Yea, the tuner is capable of doing it. I also want to delete the EGR. i know thats no Mileage gainer but... I guess i better do the exhaust next. also want to put the Air Dog system on there too. other that that ... thats about all i want to do
Thanks
D.N.S.
08 250 3" Lift
Diamond eye 4" Down-pipe back
No Limit Fab CAI
No Limit Fab. Egr Delete
35" nitto's
H&S Mini
RichardT is offline
post #4 of 14 Old 04-08-2014, 11:04 AM
WoodBoy's Avatar
Do you do a lot of idling? Mostly city driving? With the mods Kris listed I would say you may can get in the 13mpg range if you are averaging 10mpg.. Its a tuner/dpf delete/ and intake, not a miracle.
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #5 of 14 Old 04-09-2014, 02:27 AM
B585Ford's Avatar
Those numbers (if accurate) seem a little low unless you do a lot of stop and go driving or have a heavy right foot. How often does it go into regen?
To answer your question, yes, you need to do the exhaust. Deleting the DPF should make a difference.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #6 of 14 Old 04-09-2014, 10:23 AM
you also need to quit relying on ANYTHING the gauge has to say.
You don't need a full exhaust - you can go on Craigslist and buy a delete pipe for 75 bucks and spend about 30 minutes removing the DPF and your mileage will go up, but as said it is just hard parts, not a miracle and make DAMN sure your tuner is dpf delete capable.
I went from about 10.5-11 to north of 13 in my 4X4 dually and I do a LOT of idling (About 50% according to my Nav system). On the highway you can get much better mileage at certain speeds...
seafordguy is offline
post #7 of 14 Old 04-10-2014, 09:20 AM
BigRed08F250's Avatar
Make sure you change your tire size on your tuner. That could be why your dash is showing such low mpg. As others have said make sure you hand calculate it.
BigRed08F250 is offline
post #8 of 14 Old 04-14-2014, 04:50 AM Thread Starter
I don't have to do the hand cals. I'm filling up 1 a week and I'm not driving that far, I did the tire cals also Its just Horrible on fuel, Next is the exhaust. Look I knew that I wasn't buying a mileage buster but 10mpg's that's not to good My 7.3 got 15+ loaded or unloaded. with the same size tires, basically the same set up. I at least thought by getting the H & S tuner and the No limit intake I'd get at least I boost in mpg. quite the opposite it went down. we'll see after I do the exhaust
RichardT is offline
post #9 of 14 Old 04-14-2014, 04:55 AM Thread Starter
SORRY JUST GETTING ACK TO MY CPU. no I don't do a lot of idling, my commute is 50% highway, And I don't put my foot in it , lately I've been babying the crap out of it 65mph on the highway just to see. not looking for a miracle just maybe 13mpg 15 would be a miracle. I've tried all the different setting on the tuner still the same.
Thanks all
D.N.S.
08 250 3" Lift
No Limit Fab CAI
35" nitto's
H&S Mini
RichardT is offline
post #10 of 14 Old 04-14-2014, 05:22 AM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
How far is your commute Richard? The thing about the 6.4 is the compound turbos add a lot of air to the system (and hence more fuel is put in it). It is also programmed to get to temp as fast as possible (a DPF thing. I know you don't have that, but it's still programming). So it puts more fuel in to get you warm faster (also poorer MPGs). I noticed a decent bump in mileage when I started starting my truck 5-10 min before I left to try to get the oil/coolant temps above 120-150 before I left in the morning (min I try to break 100). Diesels don't burn a lot of fuel when they idle. I also use my high idle when I'm warming it up.
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
