whats a good tuner for the 6.4 - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 16 Old 04-05-2014, 05:02 AM Thread Starter
I just picked up a 08 f450 and i wanna get the dpf delete a intake and the egr delete also but what a good tune for the dpf delete just want about 60 to 75 hp tune just using it to tow my boat.. and thanks new to the 6.4 was a 6.0 guy so not scared to work on them myself
Fountainkid101 is offline
post #2 of 16 Old 04-05-2014, 06:33 AM
Bump To Pass!!
toren302's Avatar
Quoted: 1680 Post(s)
Uh Huh...Sure...
Thats how it starts!!
I can tell you that I have installed sevral H&S tuners on deleted 6.4 and I run a spartan. Those in my opinion are the only 2 options to go with. They both give you a wide range of tuning, starting at stock all the way up to 350+ extra HP. The H&S is more user friendly. It is also shift on the fly if you get the right one. There are a ton of threads about which is better. There is a running conncensus that the spartan has worse shifting, but I love mine. Is it firmer than the H&S you bet but I like it. I also dyno and track my rigs so I am used to hard shifts.
Either one is a good option. It comes down to prefrences. I will tell you the most annoying thing about the spartan is it doesnt turn on with the key. You have to power it on manually everytime you get in the truck if you want to monitor things. You can set it to auto off but it wont auto on.
toren302 is offline
post #3 of 16 Old 04-05-2014, 05:04 PM
Love my h&s
seafordguy is offline
post #4 of 16 Old 04-05-2014, 05:40 PM
It's also going to depend on your budget for the tuner. H&S mini maxx will run you about 2k new or around $1,500 used. Spartan is $1,500 new and about $1K used after relicense. If you can find a used sct 3015R or 9625OR those are also around $1k. But offer no monitoring like spartan and H&S do. There is something called dpf-r that's around $500 but I don't believe it allows for removal of the EGR valve but does turn it off from my understanding. Me personally I run spartan and love it. The shifting is a little rough if you run the 250 and up tunes but it smooths out big time with the miles.
2008 CCSB Lariat
Spartan 250EL
Flo-Pro 5" DP back
S&B Intake
Sinister EGR Delete
Kris 6.4 is offline
post #5 of 16 Old 04-05-2014, 07:12 PM
lildevil02's Avatar
Look at the SCT tuners if your trying to save some money. Best bang for the buck & the custom tuning can't be beat.
lildevil02 is offline
post #6 of 16 Old 04-05-2014, 08:21 PM
Rocweiller's Avatar
Quoted: 2 Post(s)
Spartan, is what I have. I have never ran sct or h&s on my 6.4 . Had sct on my 6.4 but it wasnt an option I went for with this truck. I personally don't care about the shift on the fly set up, couldn't do it with the sct on the 6.0 so why care now.lol
2008 F250 XLT SBCC grey flake, 33x12.50 Toyo m/t's on 18 inch mammoth wheels. Rhino lined go rhino nerf bars. S&B cai,Spartan tuned and straight piped. Fake *** chrome grille removed and a matching colored grille put in place.
Rocweiller is offline
post #7 of 16 Old 04-05-2014, 08:57 PM
cbenn's Avatar
Quoted: 2 Post(s)
I have run SCT (gearhead) then went to Spartan, then to H&S, sold the H&S. Run Spartan most of the time as to run my SCT w/gearhead I have to change out my TCM as I run a Spartan TCM and that is somewhat of a hassle so mainly keep the Spartan loadeed (275) the shifting on Spartan is right on in my opinion but I also run PMF trac bars so shifting harsh is not noticed, but either way in my opinion either SCT/gearhead tunes and or Spartan. But again all 3 are top notch and you can't go wrong, comes down to the amount of dollars you want to part with.
Just purchased a new 2016 CC
SOLD
2008 F350 CC SRW, 4X4/LB
Spartan Tuned/Spartan TCM
1722 Elite Head Studs/ChromeMoly pushrods
Bullet Proof 1/2 oil cooler kit
4" Down Pipe/4" DPF/Cat Delete
Diamond Eye 5" DPF back/5" Areo Turbine Muffler
3" CAI/inter cooler
S&B-CAI
CCV mod w/catchcan
Big Wig Sway Bars
PMF Traction bars
Icon 2.5 front coil springs
Bilstein shocks/Top Gunz dual stabilizer w/Bilsteins
Airlift/remote airbags
Viper 5701 w/SmartStart
cbenn is offline
post #8 of 16 Old 04-06-2014, 11:37 AM
Take a look at the general 6.4 mods write up in the general 6.4 discussion area. Everything you need to know is in there
2006 F250 EC/SB - SOLD
2010 F250 CCSB
Spartan, 5" dp back exhaust, s&b intake, fuel boost 18x9, 315/70r18 toyo mt
06psd6.0 is offline
post #9 of 16 Old 04-06-2014, 06:26 PM
a week ago I did dpf&egr deletes with the sct livewire I've not gotten my truck outta the driveway It surges when It is put under load in all 5 tunes. (sucks)
I've been in touch with the programmer he says it my truck an not his tunes any thoughts anyone else had this problem? Here I sit 08 450 in need of help
Travistoys is offline
post #10 of 16 Old 04-06-2014, 06:35 PM
Rocweiller's Avatar
Quoted: 2 Post(s)
Can you put to a some what stock set up? Like stock dpf off tune
