Coolant filter question - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-03-2014, 05:50 PM Thread Starter
stroke'n'drive's Avatar
Just bought a coolant filter kit from dieselsite for my 08 6.4. Tried looking around cause the instructions say I should have a hose going to the top inlet of the overflow but that's blocked off and I saw where people moved the hose from the bottom to the top and plugged the bottom but I don't know where that leaves me with what hoses I have to tap into for it. Do I still tap into the ones the instructions say?
stroke'n'drive is offline
post #2 of 4 Old 04-03-2014, 06:15 PM
StrokiNDieseL's Avatar
Google 6.4 coolant filter installation, the thread on this org should come right up w/ detailed pics. Bottom heater hose behind intake, then top hose running back to degas bottle. Good luck, Jayson.
08 F250 6.4L
CcSb Lariat 3.73
5200lbs springs, rear blocks removed, Nitto Grapplers
aFe Mag Force II Si pro 5R w/modded box
H&S MiniMax/Mcc & Gearhead tunes w/Blendmount
aFe Mach Force XP 4" Exhaust w/downpipe
Custom-Diesel Deleted, H&s wastegate w/Intake Elbow & CAC pipe, MPD Ccv/Oil fill mod, Alradco intercooler,
SD Coolant filtration/ CAT ELC...
StrokiNDieseL is offline
post #3 of 4 Old 04-03-2014, 08:01 PM
Capt dong's Avatar
Quoted: 5 Post(s)
You should tee into the overflow line that lays on top of the fan shroud toward the passenger side. Then tee into the aforementioned heater hose by the firewall.
08 F250 KR
08 F250 XL
Capt dong is offline
post #4 of 4 Old 04-04-2014, 04:26 AM
Go on sinister diesels site they have a step by step install guide for theirs both kits look the same so should be a good guide for you.
2008 CCSB Lariat
Spartan 250EL
Flo-Pro 5" DP back
S&B Intake
Sinister EGR Delete
Kris 6.4 is offline
